I’m looking for a set of these for my WT trim Silverado, I see there are many different colors/woods from geo jigsaw, cypress hewn, anteak, savanna mosaic, etc etc available from the GM part sites. Does anyone have pics of the actual wood type to match the name so I can see the colors? And does anyone have a set they don’t need, perhaps they would sell? Thanks in advance
That picture you posted is the geo jigsaw pattern. I believe that's in the Denali and High Country trim trucks.
I don’t think that’s what comes on the Denali and high country since that’s the pattern my 21 RST had.
Also you’ll notice the door pictured doesn’t have buttons for seat memory or mirror folding which are high Country/Denali standard features.
Edited by Dirk13
