Hey, what would you all do to tame down the noise from my exhaust? I have a full 3in true dual with an x-pipe (I'd like to keep this setup). I love the sound and loudness, but it's starting to annoy my wife, unfortunately. To make the wife happy I was thinking of adding a muffler or resonators on the back. Should I take the x-pipe off and replace with muffler, should I keep the x-pipe and add resonators, or keep x-pipe and just put a Flowmaster after it?
Edited by coryb3006
Does it have mufflers on it now? If it does I would just change them to something closer to stock, if not add some down stream from the X, no reason to change the configuration
It doesn't have a muffler. It's a custom true dual straight pipe with an x-pipe in the middle. Yeah, that's what I was thinking. I just needed to see what would be better to tone down the noise at startup, idle, and cruising.
Edited by coryb3006
Haha!!! It has both cats. On start up it's about 103db. I would go louder with it if I didn't have toddlers that I wake up in the mornings.
Edited by coryb3006
Add two smaller mufflers or two resonators.
I had a 2006 Sierra that had no cats into a magnaflow muffler dumped after the rear axle, it was way to raspy and loud in the cab. I bought a ultra quiet resonator and put it before the muffler and it took away all the rasp and drone basically went away.
Having cats helps you here, so a muffler(s) or resonator(s) should do the trick. Stay away from anything with a chambered design if your aim to make it more quiet.
    LeeBob
    LeeBob
  • Who's Online   3 Members, 0 Anonymous, 1,122 Guests (See full list)
