The duramax weighs basically triple what a 5.3 does, so remember that.
Everything will be custom. A few guys have done it but it's a very lengthy process. Have to make a new crossmember and motor mounts, need to run a aftermarket suspension setup with coil overs to handle the weight. Then you have to figure out what transmission you need/want to run with it and make custom mounts for that too. Whole entire new fuel system for the diesel engine, intercooler setup, larger radiator and so on.
I know of an old Chevy dualy with 12 valve conversion years ago. And a ram charger with a 4 cylinder Cummins. He got the engine from us. Drove that thing for years delivering parts. In this case it’s too new. I’d go with a modified 5.3. It’s more straightforward probably way cheaper.
It can be done. The body is same on a 2500/3500 so the engine fits, it's just making it fit the frame with modifications and grille. Aftermarket radiators and intercoolers would need to be used.
Here is a build thread on a 2001 truck from years ago. Stuff starts to happen on page 4.
https://www.performancetrucks.net/forums/projects-gallery-189/back-game-rcsb-1500-d-max-swap-coming-514649/page4/
On 12/29/2022 at 8:28 AM, 64BAwagon said:
I would bet theres nowhere near enough room under that hood to jam a 6.6L into that chassis. Especially when you consider the radiator and intercooler sizes.
Duraburb does 1500 conversions with those motors.  When they're done, it all looks stock.
Edited by swathdiver
    ballencd
    ballencd
  • Who's Online   5 Members, 0 Anonymous, 517 Guests (See full list)
