Hi everyone, Im new to this forum, I drive a 2020 AT4 6.2, truck has 42,000 mil. Truck is runing good and strong,  but a while ago started to act weird, when I put the truck one reverse and I press the pedal (a lil bit, for the truck just to move, like when you in the mall) you can feel the engine like vibrating and when I put the truck on drive, it shut off (but not always), I put the truck back on park and it start right away and put it on drive and work just fine, when Im driving down the road the gruck works fine, is just when is idleling in reverse. I want to know if some one has this problem before or have any idea what it coul be
That sounds weird and almost like your stop/start system is not right.  So when you idle in reverse engine turns off.  What happens when you shift to drive or park?  Does it restarts or is it a stall and you have to restart the engine manually in park?
This happen even when the auto stop/start system is off. So, when is in reverse and I give it little gas just for the truck to move and then put it back to drive and press the gas pedal a lit bit, to start going, you can feel like the engine want to die(in some cases it dies) but if I let got the pedal, boom the truck dont shut off. And when it shut off on me, I just put the truck back to park and manually start it, and it work just fine. This happen mostly when you shift from reverse to drive in low speed, like when you at the store or at the mall parking lot when you going carefully. Is going to sound stupid, but is like when you have a weed eater and is running good in idle, but as soon as you want to start working you give it some gas and it dies, in my case it dont wappen all the time.
Another thing,  is in the mornings, when the truck is "cold" the rpm's are up and down, almost to the point that you can hear the truck is about to shut down
Edited by AT4Juan
I tend to agree with Tim with it being electrical.  Set your ebrake and have someone exercise the vehicle a little while you observe under the hood.  Could be simple chafing on a harness that moves ever so slightly when you shift into different positions.  Might also consider just letting it idle in park ebrake set and crawl under the truck moving harnesses by hand.  Any kind of harness issue could cause a communications issue that results in a stall.  Still under warranty?
Update...
I remove my coldair intake tube to check the throttle body for any oil residuals from my intake and sure thing the walls and the flap were dirty and oily, not that bad but still dirty. I took it to the dealership to get it clean and most important re-learned, I was thinking to do it myself because its easy, but then the relearn thing, so naahh. They clean it real fast, I was in and out in less than 45 minutes and the truck its been running good for the last 5 days.
Edited by AT4Juan
On 12/27/2022 at 8:04 PM, AT4Juan said:
Update...
That is weird.  hard to believe a cold air intake tube...wait....relearn what?  There have been people who upgraded to the GM cold air intake and failed to get the calibration for the MAF complete and had all kinds of drivability issues.
I guess the throttle body got dirty because of the oil from the intake. Some times when you remove and clean the throttle body you need to "re-learned" or calibrated, so thats what they did. I guess is not the first time they had some one with that problem, because the mechanic ask me what was wrong, so I explain him and he was like ,"oh you put the cold air intake". He told me that the throttle body needs to be clean all the time.
Guess I learned something new.  Wouldn't have thought they would remove the TB to clean vs using upper intake cleaner.  I've never cleaned my TB...just use top tier fuel and the right oil.  Glad you got it sorted.
12 minutes ago, asilverblazer said:
Oiled air filter?
Yes, the oil from the filter started to acumulate in the flap and walls of the throttle body
Did you switch to a paper or other non-oiled filter?
It's not getting too dirty from PVC is it?
I switch it to a non-oiled filter, a dry filter
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
