So I was having some trans temp concerns in my 2016 z71 silverado. I noticed the temps during the warmer days and stop and go traffic would creep up close to 180-190 and 147 on cooler days. I replaced the thermal bypass valve with the upgraded bulletin one with the 70 print from GM. I don’t haul at all but do a lot of city driving. Should I purchase another thermal bypass to another with the 70 print or if the temps normal??? I know GM said you should only need to change it once unless it’s faulty. But I don’t know if it is or not. I was 64 degrees in Philly today and got up to 178-180 range
Edited by Rickyace09
  • Rickyace09 changed the title to 2016 z71 Silverado 5.3 trans temp help!!!
A simple test to see how it's working would be to go a route somewhere without lots of city driving.
If the temps stay around 150-170 degrees, then the thermostat is working correctly. Buying a new one at that point wouldn't help any.
If you wish to bypass the thermostat just flip the pill inside the thermostat and it will be open 100% of the time. If the temps continue to still be high after that you have internal transmission problems. Like a slipping torque converter.
Edited by CamGTP
190* is too hot; even 170* is at the farthest realm of proper.  Here's my data points: After I upgraded the GM Thermostat two years ago, I towed my VW 200 miles on a car dolly (crossing NYC) in early August, and never saw trans temps higher than 162*F.  This past December, I towed my 442 and my '84 GMC 200 miles each way on a 2k lb u-haul trailer on the same cross-NYC route, and never saw temperatures leave the 140s.  This route, in addition to crossing NYC onto Long Island, also includes crossing the Taconic Mountains in upstate NY.
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 695 Guests (See full list)
