8 hours ago, BigMick2023 said:
My 2023 Silverado High Country ACC is flakey also.......
It will sense a car in the next lane over and slam on the brakes when I start to approach it.....had it do the same with a car entering the freeway on the acceleration lane and putting myself and vehicle behind me in a panic situation that was completely unnecessary.
It's a hazard in itself IMHO........talk about getting rear ended when the brakes are slammed on for no reason.
Turn it off.......drive alert and use your own senses, not some computer and camera.
Perhaps the dealer needs to re-align the camera that is in front of the rearview mirror.
It’s happening on both sides of the vehicle explain that???
not sure how that could be an alignment issue….
Might not be the adaptive cruise, but the truck is seeing something that is causing emergency braking to kick in or has a faulty camera or sensor sending a signal so the truck 'thinks' something is there.
All '23 1500 pickups have UHY and UKJ
......or it's a piss poor design and/or implementation. Try mentioning it to the dealer and they say it works just fine.
During a test drive of a different 2023 High Country than I purchased, with the sales guy in the vehicle, it did the same thing. Excuses from the salesman abound.
Turn it off and problem fixed.....not worth the hassle or safety issues it presents.
Edited by BigMick2023
On 2/24/2024 at 1:42 PM, SHERYL SKRZYPCZAK said:
My brand new 2023 Chevy Colorado ZR2 has been randomly braking, slaming from 75 down to 40. Absolutely nothing around. Clear day, straight roads. I've had it in 4 times, 2 different dealerships. Their solution...they disabled the feature. A safety feature option I paid for. I contacted GM corporate, they contacted the dealerships who said the feature works as it should. If it's working as it should, why disable it?
Hello, SHERYL SKRZYPCZAK. Please know our team is only an email away if you are ever in need of assistance. Thank you and have a great day.
  • 5 months later...
This has happened several times on my fathers 2023 Chev Silverado.
Solution: Dealer says turn off adaptive cruise control.
Asked about a refund - they offered a free oil change.
Someone is going to be killed due to this problem...I suppose that is when they will be force to do something about it.
I have a 2021 Silverado High Country. Great truck. But the ACC has tweaked on me as well but only when going uphill. It's as if the computer is interpreting the road as captured by the camera as a collision threat and then braked very hard causing me to have to turn the cruise off as quickly as possible to regain speed and actually avoid someone from colliding with me from behind! Then...the ACC won't rearm for several minutes thereafter for some reason. It's frustrating since I do like the feature even though I don't rely on it to text or otherwise not stay alert. There are too many "non-alert" drivers out there already to do that! It doesn't sound like there is a universal diagnosis of the problem or fix either. Someone mentioned using cruise control without ACC. I guess I didn't realize that was possible on a vehicle equipped with ACC. How exactly is that done? Thanks!
When it activates, the text box that comes up should indicate which mode it is in, and how to change modes.
It's also in the owners manual
(this is from a '23 manual, but it operated the same on my '21)
Edited by redwngr
    nolankd
    nolankd
  • Who's Online   3 Members, 1 Anonymous, 460 Guests (See full list)
    • For a limited time, retail accounts receive a free fender cover (G2803) with their order of $750 or more when they use code FENDER926 at checkout. The promotion runs through Sept. 8, 2026. Own a business and want to apply for a retail account?  Apply here. https://www.amsoil.com/business-opportunities/sell-in-your-store/?zo=521390
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
