First of all I am not a mechanic, I am just trying to save some money,  and I am replacing my blower fan and resistor.
I have watched some youtube vids and replaced the blower but I can not find the resistor. Can someone, please point me in the right direction?
Edited by octobers fade
Adding pics
Watch this video & see if this helps...
Thanks for the vid  it is a totally different set up.
I have watched a lot of videos but none have the model and year that I have.
spelling
The resistor is built into the blower motor assembly.
This is straight from a parts listing for the blower motor with AC Delco. It doesn't matter what cab or anything, it's all the same.
Quote
RWD; Standard Cab Pickup; MOTOR INCLUDES BLOWER MOTOR RESISTOR PER SI DOC 5258735
Edited by CamGTP
Maybe this will help???
You can check this by accessing the panel behind the fuse box, and looking for the resistor module. Once you locate the resistor module, inspect the metal connector. If it needs to be replaced, you must cut the connector, splice it, and replace it with a new connector.
https://chevroletforum.com/how-tos/a/chevrolet-silverado-2014-present-why-does-my-blower-motor-not-work-389341
Thank you that explains a lot!
Nothing I found searching, or videos I watched  said that.
  • 1 month later...
Ok, I asked the shop that was working on my truck and got an answer:
The resistor is not a part of the blower motor and is located behind the dash,  the book time is a four hour job and I was quoted $650.
No wonder there are zero vids for the repair and little info out there about it.
  • 1 year later...
Can you elaborate on what the mechanic told you about it being behind the dash? There is absolutely nothing online that shows where this resistor is. I have a 2016. I also dont follow where Mikeyk’s picture is. I have looked all over and I don’t think that’s the same as my 2016. I replaced my blower motor and I still have the same issue, after 10 min or so the fan slows down then stops blowing much at all.
  • 3 months later...
  • 1 month later...
    tblt44
    tblt44
  • Who's Online   4 Members, 0 Anonymous, 709 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
