So randomly my AC in my 2014 silverado went out, had a mechanic come and check it out and the pressure was too high so he drained and corrected both low and high sides, AC was still blowing hot, we checked the compressor and it was engaging, condenser had no leaks and the lines were not clogged, he ran it through the computer and we got code B-1325-03 and read as low voltage so the mechanic told me it was an electrical issue, maybe a bad ground, i've been searching everywhere and could not find any solution, anybody know what might be the problem?
Recover the refrigerant. Change the txv and the filter drier in the condenser.  Pressures being high is a restriction in the drier. Correcting pressure means nothing at all to be honest he knows not what he speaks.
Put the new parts in and new 134a and enjoy.
I've been a legit HVAC tech for 13 years. I've seen my share of shadetree techs.
Could also be loaded with air, too, especially if someone tried to recharge it not knowing how those parts store can taps work. That'll send pressures sky high and blow warm. A fan failure will, too.
No airflow over the condenser, or a plugged up condenser (Check between the rad and condenser for tree debris, mouse nest, etc.) sends the pressure REAL high.
Systems don't suddenly have "high pressure", unless overcharged, or having the aforementioned issues.
Edited by Jsdirt
It’s amazing people with a license think they’re so much smarter than us shade tree techs. I’ve worked on everything with tracks and wheels without that piece of paper. The only reason I worked on my stuff early on is it was cheaper to do so. I still do on the easy stuff the paper people want to charge big bucks for. 40$ to change a cabin filter. Same with air filter. I spent 1/2 hour changing my Honda transmission fluid. I didn’t even have to jack it up. With the internet if you can read you can do anything. I happen to find techs I can trust so I use them. Remember the geniuses at GM came up with the 5.7 diesel and cylinder deactivation. Give me a break. If anything the paper techs should be happy if someone screws it up. It gives them an excuse to charge more.
Just like the kids these days throwing shade... sad AF, bro.
I do not think I am smarter then anyone. I will call it like I see it tho.
Bs.
When someone comes to the net asking for advise should I just dumb down or advise as I was taught?
Bs.
Edited by KARNUT
How is 5.7 diesel and cyl deactivation techs fault?
At what point in your ramblings did you offer assistance to the OP?
I actually did in another AC thread. As I fixed my AC today that was low on Freon. I read more than one thread.
I'm going to be clear. I my original post I was not throwing a punch at anyone on this site.
I think we all here have seen our far share of people getting shafted. Alot of them come not even knowing they did get the tail end of the deal.
Because I care for others... it's frustrating to see someone come with issues that can be sorted out with ease- especially since Google and youtube have most info anyone working on anything will need.
Reading the OP I hear the same thing everyday. Last tech adjusted the pressures.
Basically he took/ let some gas out to get the head pressure down.
Like jsdirt said look at and clean the condenser coil. It is located in front of the radiator.  In lue of going back to the tech you can purchase a Water Saber .  This connects to your garden hose and will flush out the radiator, condenser coil, trans cooler and you can use it to clean any place on a vehicle you can not reach.
Good help is hard to find these days across ALL lines of business.
Case in point, I just spur-of-the-moment bought a pristine, 30 year old Cummins-powered Dodge pickup (That I should've bought 16 years ago instead of my Silverado, but that's another story for another day!) - my insurance company, which I happen to now work for in the maintenance department, emailed me a document and said I was good to go to the MA Registry (RMV) to get my plates transferred. Well, the document I received wasn't anywhere close to what was needed! Thankfully, due to 5-decades of living in this S-hole state, I knew something wasn't right, and asked questions. I got the correct documents only after questioning! Had I been a 16 year old kid that just got his license, I'd have waited there an hour only to be told EVERYTHING is WRONG!
On that note, because this is the over-governed (By MORONS, too!) state of MA, I couldn't transfer the plates ... because my wife's name was on them - she had to co-sign the loan for the Silverado in '07 because my credit sucked. SO - I waited there an HOUR for them to tell me this! I lost it on the poor girl teller - she asked me to stop swearing at her. 😆 I had to leave, drive 20 miles home, get my "wife's permission" (LOL!!!) to transfer the plates in writing, to bring another 20 miles back, to sit ANOTHER hour to get my registration and title!!!  😠 This state will drive you INSAAAANE with the idiocy!!
That's what I did the first 6 hours of my day today! If anyone tells you to move to MA, RUN the other way!! 😂
Hopefully someone can now laugh at this story. 😜
  • Haha 1
I'll tell all the folks moving here MA has the form of governing they are used too!
Just gas up and keep going to MA!🤣
Edited by Snowcamo
  • Haha 1
My wife goes to the rec center almost daily to swim. Almost daily she meets blue state transplants, most from California. They are tickled that they sold their million dollar house and bought for much less here. Are amazed that prices are cheaper here. Then they complain they can’t find like minded people.
  • Haha 1
I fear soon enough the state will turn blue.
The amount of folks moving here is like dumping ants on another ant mound.  Crazy
  • Like 3
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
