How did you guys split the signal? I did a search and cannot find where the signal comes lfeom the amp, to up front then splits to the 6x9 and full range separately. Is it in the door?
Did you just put the woofer in door and tweeter in the dash basically cutting out the crossover since (based off RTA pictures) Looks like it's already in being done
Currently have infinity ref 2 way in doors and the popular KFC excelon in the dash.  Its OK, but thinking I want a true component set to help staging and leveling.
Speakers will be ran off a key 200.4, haven't decided on active or passive..
Edited by Russ757
I put the jl c2 650 components in the door where the 6x9s were previously.  I extended the wire connected to the stock 6x9 to the jl crossover and then ran wires from the crossover to the tweeter and 6.5" speakers.
In the end, I ended up going from a 7 speaker bose system to a 10 speakers in my truck.
And you ran the tweeter wire through the molex connector?
No, the tweeter is in the door above the 6.5" speaker.  the crossover is mounted behind the door panel.
Edited by homermacleod
    • You won’t do better than stock exhaust without headers. Just put your favorite muffler on it and it will do the job.
    • I have seen different people in different places post different sizes of exhaust as stock for my 2014 Sierra L83. Some say 2.5 some say 2.75. I am considering replacing the muffler with a Dynomax Super Turbo, perhaps 17739.  I had the factory L83 5.3 replaced with another L83 5.3 from Jasper Engines. I also put new Walker Cat / Y pipe on. I would appreciate opinions suggestions about what would be a good muffler setup. My main interest is a low rumble and the best flow / fuel mileage I can get. Not interested in straight through glass packs or loud exhaust. Those days are way behind me now.  Thanks Guys.
    • Its coolant disguised as oil.   TSB 20-NA-166 -  20-NA-166 1..3   "To inspect for this concern, add coolant dye to the system, run the engine through warm up, pressurize the cooling system after warming the engine to operating temperature (let the engine cool overnight) and inspect the suspect cylinder with a borescope for coolant dye evidence. At times it may be necessary to remove the head for inspection. If the head casting line is the concern, the intake port will be wet with a coolant oil mix"     I'd say its the head, and its either leaking at the casting line and dripping down the intake into the cylinder, or its another spot on the casting itself at the cylinder that is getting wet.
    • Can you sample the pooled liquid, enough to confirm it is oil?   ...That its not fuel or coolant.   Also, make sure combustion gases aren't entering the cooling system.   Simply put, either oil being pushed up past the rings (this really isn't possible), oil leaking past the head gasket, oil leaking past the valve, oil entering through the intake air path. If none of this is likely - it may not be oil.   What could be likely is the fuel injector leaking down. A puddle of gas would still smoke and rough idle. (Same cylinder has the same problem after injector replacement?)   What is the crank time first thing in the morning, when the puddle would be present? Does it seem like the high pressure fuel pump needs an extra second or two to rebuild the pressure that injector 8 may have let bleed off? Check the fuel pressure via a scanner prior to starting the engine.
    • Good information!  I didn't know about the dementia aspect and asked for a general for my second knee. I'd heard that recovery room time is usually shorter with a general.   The anesthesiologist talked me out of it and I had the spinal.  Inconvenience and/or discomfort is a small price to pay for reduced risk!
