Does your truck come with the Bose premium sound system? Mine sounded a little muddled when I first got it. Played around with the audio control a little and now it sounds very good.
Assume this is the reason you're looking at dash speaker replacements?
I do have the Bose system. A friend said the tweeter on the Pioneer dash speakers don't play. He bought two sets. Returned both.
On 12/4/2023 at 8:26 PM, traderfjp said:
Anyone try Pioneer TS-A709 for dash speakers? They look interesting.
I used tsa706 for the from dash they do great in my 2023
13 hours ago, Mshawn said:
My apologies I did get the TS-A709 pioneers for dash speakers. They are 4 ohm.
Does the door chime and turn signals sound OK with the Pioneers?
Heard others complain about it with aftermarket speakers.
On 12/7/2023 at 6:26 AM, traderfjp said:
You can hear the highs? The tweeter works?
Yes makes the whole system better but you’ll want to ad an amp later.
I didn’t use the kenwoods kfc -x2c but I hear a lot of good reviews from guy with our trucks. I’m going to order them and do a comparison. The door speakers , kenwood KFC 6696s are awesome in the front doors lot of bass and very clear highs and mids
My apologies these are pioneer tsa 709. Yes they are very good
1 hour ago, Mshawn said:
Yes if you do not use the inline crossover!
If you do use the crossover do you loose those sounds?
I see Crutchfield is out of stock.....bummer. I have points I can use there.....
That's a great idea. I woukd think the Pioneer speakers woukd be more go higher and sound brighter.
    B07
    B07
  • Who's Online   1 Member, 0 Anonymous, 887 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
