I am trying to find a part # or link to buy replacement weather strips for the doors. It’s where the window meets the door (rubber).
I found a couple Y tube links but most broke the clips when removing the whole chrome trim piece
I would like to replace the rubber only if possible.
Any direction to get these replaced is much appreciated.
thanks!
Edited by Wyatt1963
Clarification
Here's a link to the rear door exterior "Window Belt Reveal Molding" BUT it's for my Double Door. You would need the "Full size Cab door". It appears that they do not list the rubber by itself. Maybe some on else can give a better link. It might be a starting point on your search.  Good luck.
23227178 - Rear Driver Side Door Window Belt Reveal Molding 2014-2019 GM | GM Wholesale Direct
Here's a good video on removal. Again, good luck.
Edited by rav3
You just have to go further down in the main page for them to get to the crew cab parts. The first several listed are for double cab but further down you will find the crew cab ones and then get part numbers you need...
https://www.gmwholesaledirect.com/v-2017-chevrolet-silverado-1500--ltz--5-3l-v8-gas/body--exterior-trim-rear-door
Thank you for the direction on this.  For the driver side front only $63 and for the drivers side rear $120. Interseting they look so similar but one is twice the price. I may wait until they have an agent on duty to verify the pricing but this looks so easy to replace. I was really hoping to replace the rubber only but I dont see that as an option.
Does $200 for both doors on the drivers side sound about right? I understand the crew cab may be more $$ than the double.
Thanks again for taking the time to respond.
Merry Christmas!
Do a search for you part number to find the best price. I just posted the first site I have book marked to find the P/N. I'm sure you can find a better price out there.
That's actually not a bad price from that site. But you need to pay attention to shipping costs and that's where they get you. Some will offer free shipping if you order over a certain price.
Another option once you get the part numbers you need is to order direct from Chevrolet. https://parts.chevrolet.com
Once you pick a dealership to order from, the price is usually under MSRP as well. They also give you the option to have your parts shipped to a local dealership and then the shipping is free. They also have discount codes depending again on how much you order, from 10%, 15%, and 20% off. The codes are right on the Chevrolet site.
So like I mentioned, compare the cost and shipping charges on several sites but then compare the price with free shipping from Chevrolet...
Good points
thank you and hope this helps others
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
