     I have a 2000 Chevy Silverado 1500 4x4 5.3LT,  I swapped out my 4l60e tranny for a used good running one, I struggled but got er in. I started her up and she was a little rough at first but ran fine, I put 4qts of ATF in and she read over full hot and cold check. So I pulled tranny to seat my torque converter, I didn’t pre fill it either. Anyway after that I couldn’t start her. So a new neutral safety switch I put in and new plugs to it. She would turn over but not start at this point. No spark it sounded like. So I checked the spark plugs and all 8 coil packs power to packs but not to plugs and no spark in any of them. So I proceeded to check all the fuses, relay’s & sensors that had anything to do with the ignition/ starter system. Everything was working. So I checked the PCM plugs, battery cables and all wiring to coil plugs. All the ground wires under the hood. I reset the security program in case it locked up something in the ignition system. I was told maybe check the Crank or Cam Shaft Position Sensor? I am at my wits end and still can’t get her to do anything but turn over, she started before?  What am I missing? All 8 coil packs are not getting power to plugs and all 8 plugs are not sparking it’s gotta be something simple? Please help no one on this end can figure it out… thank you ahead of time!!
Edited by Hot Blonde
Check for the wiIring harness that runs over the transmission bell housing to the back of the right (passenger) cylinder head. Make sure it didn't get pinched between the trans and the engine block. Also make sure the ground on the back of the head is secure/tight.
The coils are triggered by a ground pulse from the PCM not power. The crankshaft sensor is on the rear of the engine above the flywheel so I bet it may have become unplugged or the wires pinched when you pulled the trans
I will check to see if it came unplugged and will check to see if any wires got pinched and will check the grounds again as well. I will let you know..
    • There would be one way of determining the quality of the factory oil although probably more than a typical oil lab test, and that would be to draw out some oil from a new truck and send a sample to a lab that could do a more elaborate test of the oil. The issue with too little oil in the diff may not be the lack of lubrication of the diff bearings and gears themselves ( although a lack of oil volume for cooling ) but the wheel bearings because at some point the oil would be too low to properly get onto the spinning axle or fed along the axle tube. That was the claim by the local dealer from a couple of trucks in recent years that had the wheel bearings fail and they figured from lack of sufficient oil due to a severe underfilled diff and some of the bearing material made its way to the diff and it got damaged as well so the axle housings were just replaced on warranty. But your right that if the diff is over filled by whatever margin that it causes more churning of the oil than is desirable and that is no good either and can cause a pinion seal to leak. Also old oil I believe can tend to loose some of its properties like antifoaming and another good reason to change the diff oil every so often.
    • I would be surprised if the diff's were not filled (with the cheapest gear lube) at the axle factory before being shipped to GM.  If you ever watched them building trucks they install the axles and all suspension parts with the frame upside down and then turn it over before its time to install the engine.     Too much gear lube in a axle can be worse than not enough especially with a lower quality GL where is get whipped up with entrained air (foam)  weakening its ability to lubricate.
    • This is the 6.6 gasser section of the forum, you should either delete or modify your previous post as it is misleading for anyone looking for factual information on their 6.6 gas engine.
    • Well....I've done my first intake gasket. Probably wrong, but...we'll see?   Ultra black on the china walls and 1/4" up onto the sides of the intake gaskets. Permatex High Tack (couldn't find Gaskachinch) on the head side of the intake gasket. I read wrong and it says you're supposed to put it on the mating surface of the head, not the gasket. Hoping it's like a PB&J sandwich where it doesn't matter what side the PB goes on so long as there's jelly. That crap is messy/sticky and I got a dab or two on the intake port openings, tried to wipe it off. Hopefully it won't be a big deal and will only aid in sealing.   Per instructions I left the intake (top side) of the gasket dry except for a light smear of RTV around the coolant ports. Wiggling the intake in there was a bear but I had help to free me of surrounding wiring/stuff but I was basically able to set it straight down lined up with the bolt holes.   I did not think to wait until the RTV skinned over but there probably was 5-10 minutes while it sat before installing the intake.   Bolts finger tight first. Then, followed the Chilton's manual pattern to snug them to 15 lb-ft.   Waited a little over an hour, and then did the final torque in sequence again to 35 lb-ft.   Yesterday I replaced the fuel pressure regulator and got my new "nut and bolt kit" (fuel lines) installed. Damn GM used security torx on the spider, which I don't have, so I got scammed at the local HW store for an off-brand security Torx bit set.   The new driver's door mirror arrived yesterday, so, there's a chance this thing could be running and road legal tomorrow? I don't want to get my hopes up.   This will be my first time stabbing a distributor, too. Although, lucky me, someone else marked the old distributor for removal previously, I did see that. (Someone's been here before!!). Engine is still at TDC so it *should* be just a matter of transferring the mark to the new dizzy and rotating it into place.
    • He has his dad’s newer truck he’s put away. He has several old cars he rotates between him and his family. I’ve seen a restored square body and a SS Chevy truck he’s sometimes drives. He did raffle off a new suburban recently. As much as he is watched if he drove new stuff as a rule we’d know it. It would be fine by me. I don’t care what people prefer. I got one more new one in me. I’d rather my wife get one. I can’t get her out of the Genesis. Don’t tell anyone. I want her to get an electric truck. I want to put a generator in the back. Just because. She hasn’t bit yet.
