Gents,
I took my 23 Trail boss on a drive yesterday and on the way up to our destination I had the heat set at 74 and on auto. It would blow between cold and warm air but it was tolerable. If I increased it to a higher number, it seemed to warm up but never seemed to stay steady. Hot and cold. Today on our way back, I had it on High and auto but I was getting lukewarm air out of the system. The engine temp was normal. External temps were around -20 on both days.
Any ideas on why? I looked for winterfronts but I can't seem to find any for the 1500's.
Provided your engine temperature was anywhere close to normal your problem likely isn't an inability of your engine to develop heat.  You might have a problem with the temperature sensor used by the vehicle to determine either your inside temperature or your outside temperature (I believe there's a separate one from the one that displays on your infotainment system).
To test this theory manually crank the heat up for all zones to the maximum it will go and crank your fan speed to the maximum.  If it puts out tons of heat then your problem is most likely in the sensors.
Also verify your coolant reservoir is full.  If somehow you get air into your heater core and it will not release that can also affect your performance
Edited by calgator73
"To test this theory manually crank the heat up for all zones to the maximum it will go and crank your fan speed to the maximum.  If it puts out tons of heat then your problem is most likely in the sensors.  "
When I did this it wouldn't kick out much heat. It was still luke warm.
My cell phone was sitting in the phone tray and when I went to pick it up it was freezing cold.
I will check the coolant reservoir as I have not looked at it.
1 hour ago, Haufski762 said:
I checked both coolant levels and they are about half way up each reservoir after the truck sat for 2 hours.
Turn on the recirc. With temps that cold wth recirc off your pulling outside fresh air in and the system has to heat that air also just press the button the little light will come on meaning in recirc mode. You will hear the difference in the fan.
Edited by Silverado4x4
Thanks. I did try it with both recirc on and off and there was hardly any temperature difference. I could hear the fan noise changing.
Edited by Haufski762
I called the dealership and they said with the -20/30 temps we have had, they have had a rash of both gas and diesels trucks coming in with issues.
I asked them if there was a factory winterfront for these trucks and they said no. Some online forums say the grille louvers are supposed to act as a winter front but they don't stop 100% of the air coming across the radiator.
I did find an aftermarket winter front but it wanted you to use buttons to secure it to the grille. Not going to modify a new truck with those.
Does anyone have a lead on a winterfront that you don't have to modify the truck to use?
A piece of  cardboard in front of the radiator used to do the trick!
Spray paint it black if you need it to look good, my 2020 6.2 has to be on 75 or above to get any heat on the feet, always been this way, I believe others have the same issue and there is likely some sort of issue with the venting system not operating correctly.
When you did all these checks...what was your engine temp?  Another duramax forum spoke to kinked heater hose from the factory causing an issue.  Those trucks should produce as much heat as you can stand once the engine is fully warmed.
There's just days the heater is not happy. This occurs all the time to me 72 is fine most times then some days it's to cool then when I bump it to 73 the truck gets to warm. Other days it's fine. The light coming through the windows from the Sun and even the color of Paint you have seems to mess with it. Even pulling my shade back on the sunroof causes it.
It's like the temp sensor in the cabin is easily fooled by outside factors.
Engine temp was in its normal range.
Back to the basics.
Check and compare the temperature of the two heater hoses going to your core.  Better if you have an infrared thermometer.  Supply should be uncomfortably hot and return should be a slightly lower temp.
1 hour ago, calgator73 said:
Back to the basics.
Ill just take it to the dealership.
the 2.7 and 3.0 both use the same heat management system, and i think when it that cold out the electric pumps slow down to keep the engine hot. the slow circulation in the heater core is not allowing good heat in the cab. my 2.7 is the same way at minus 10 or colder, i can drive 50 miles and still only get luke warm air in the cab with the heat set at its maximum
    DM22
    DM22
  • Who's Online   0 Members, 0 Anonymous, 1,821 Guests (See full list)
    • So I'm in the middle of a DOD AFM delete on my 6.2 L86 Sierra. I had a pick holding the tensioner but after I got the Cam phaser gear off I was cleaning off all the rtv and apparently I didn't have the pick seated far enough in. I bumped it and the tensioner sprang forward.  I think everything is good but I want a second opinion. The top of the tensioner is just a looped piece of plastic that rides in that channel right? There is no spring or anything is there? I got the gear and chain back on and it seems tight and everything looks right. I'm hoping nothing fell out.
    • My 2015 1500 LTZ Silverado suddenly won't go into 4 x 4 low. It will go into 4 x 4 high.
    • Yep, just a quick reference point.    My main point being I’d do a thousand other things before I’d pay 10k for a transmission.    Speaking in ignorance cause I don’t look at these trucks, what is it worth? 20k?
    • I think users are going to want to pick their monitored parameters, which parameters they want to see first.    It should probably start with baseline at a minimum and adjust to learned, but be able to overlay baseline for comparison.   A simple severity level would be able to determine what type of alerting is appropriate or user selectable.    Why not use the OBD port though?   I think a phone connection would be a good idea, push notifications type deal.   Number 1 issue is having data is useless if you don’t know what the data should be under normal conditions.
    • I thought I would use your thread and add to it as I just did my first longer drive with my truck in the last couple of days. I drove from the Grande Prairie area of Alberta down to Edmonton and most of where I drove in the city was the ring road so fairly free flowing but a bit of stop and go as well in the city. Stayed the night and returned home and not too many stops along the way each way but every restart and certainly every cold start sets it back for fuel mileage. Why I say that is I see some people will cherry pick a fuel mileage leg after the vehicle had been warmed up driveline wise before hand and its a forgiving ( easy rolling drive leg for example ) and call that their fuel mileage which can give a false perception of reality. I was not heavily loaded at all but never the less the flip bak cover, rubber bed mat, various tools etc and extra jerry cans of fuel all way up to a few hundred pounds of dead weight so its not an empty truck. The cold inflation tire pressures are set more near the freezing point so once they are warmed up driving I was showing 45 front and over 40 rear and realize high inflation pressures would help a little in fuel mileage but certainly not the ride on our crap sections of highway. The weather was good so was not raining as that can really drag mileage down, in fact I had a bit of a tail wind on average driving home. Most people on here would never have driven on that freeway to visualize it but its got a fair bit of rolling type of landscape with numerous river valleys. For the most part I had it on cruise set to 62 although kicking it off if I caught it in time before it started down shifting and self braking going down the grades. Most of the more substantial grades its shifting into 7th I believe as 8th just doesn't have it. Total distance round trip was 643 miles and my overall average and I did refuel three times in all, figured out to 17.65 miles per US gallon. My best fuel mileage section refuel within all of this figured out to 18.46 and these are all hand calculated figures. I find if anything that the trucks computer can be over optimistic, sometimes its pretty close but other times its stretching it. On paper persay in theory the truck would have just about made it on fumes for that whole drive without refueling once.    Which made me think of the topic thread of the wonder if these trucks could do 20 mpg and that is a good question, certainly would have to be on an easy going flat highway, no head wind, the right temperature, not packing around a bunch of dead weight and puttering along even slower than I was I would suspect and going steady and not stopping to smell the flowers or take a piss !. It probably is possible but not without effort to attain that with the wind resistance and weight of these trucks. Of course on my drive most people are passing me if they have the power as per loaded highway tractors, never mind a lot of speedy vehicles but the speed limit is 68 and most are at or well over that.
