I added roof lights, factory lights and factory 2500 harness and I need to find a spot to tap power to run them. I want them to function like factory lights, on with the DRL, parking lights, with fob. I cut the end off the factory wiring harness I purchased and ran 2 wires down the pillar one power one ground, and I have a good ground. Is there anywhere to tap off the BCM with a T tap? I can't for the life of me figure out how to do this, and I'm not good at reading a wiring diagram. Is there anyone that can tell me "put a tap on the ____ connector at pin ____"  All help appreciated!
I've always wanted to do this mod but so many have talked me out of it and I'm too chicken Sh$t to be drilling holes in my 83k roof!
Why poke holes in a roof that could lead to leaks, same with my homes roof. Satellite companies mount dishes on roofs because it's easy, I told the tech if you can't mount it elsewhere forget it.
It is mounted on the ground on a pole.
  • Confused 1
Maybe it's because I'm still kind of young, but can't be afraid! Be confident in your ability and it'll come out great!
On 2/14/2024 at 7:44 PM, Mark57 said:
Like to see a picture, did it come close to antenna?
The template I used was from this forum for a 2500, all the measurements came out exactly the same.
9 minutes ago, Naughty Donkey Performance said:
Looks F'ing GREAT, links please......... or part numbers ?
Thank you! I used all factory parts, here's the list:
Genuine GM Roof Wiring Harness #84694118
OEM GM Sierra, Silverado LED Amber #84747497, #84747496
Now the 1500s aren't pre-wired like the 2500s, but all the clips on this harness will still clip into the roof of a 1500. Thought this was a nice surprise! All I did was snip the plug off the harness where it would plug into the A pillar harness and run 2 wires down the pillar. Ground one find power for the other and you're done!
Here is the link for the template, for 2500s but the measurements are all the same:
https://www.gm-trucks.com/forums/topic/248996-how-to-add-cab-lights-to-a-2020-silverado/
Thanks ordering today, I am gonna DRILL me some leaky holes..🤣
Will make  a video of the whole shebang and post er up!
Thanks again, check out the led lighting I did on the front of my truck, I think it looks nice.
Assman is because of my plate......... Donkey reference and all
Those came out very nice 👌 they won't leak, my only suggestion would be in the bottom of the lights is a raised gasket around every bolt. Factory doesn't use silicone according to my dealer... I did!
Easy to do.  Used same measurements as from a 2500HD.  No problems. No leaks,  Power wire connected under hood with "add a fuse" connected to park lights.
I'm continuously blowing fuses with add a circuit, tied to 42 parking lamp right. Any suggestions?
    DM22
    DM22
  • Who's Online   3 Members, 0 Anonymous, 2,375 Guests (See full list)
