I have a 2017 Sierra 1500 5.3 4x4. I just picked up the truck today after getting 4.56 gears installed. I noticed my speed on the dash is about 15mph faster than my actual speed, according to the speed app I was using. How do I get this recalibrated?
Edited by jsumner83
YouTube has several videos on this.
If said person has never tuned is truck before, they must purchase credits to tune it.
HP Tuners is never free to change tire size on GM vehicles.
My bad. I though you could.
Yep, gear changes will need a professional tuner application.
I do have "professional" tuner devices such as the FlashPaq (which is very good, IMO - it's a Holley branded tuner) which mainly correct for tire size.
I could be mistaken, however, as I've never performed a gear ratio change.
My Autel MaxiSys can, also correct for tire sizes but I bought that after I bought the FlashPaq. Not sure about gear ratio changes (see above.)
Edited by MikeBMW
    DaleB
    DaleB
  • Who's Online   3 Members, 0 Anonymous, 1,060 Guests (See full list)
