I have a 2024 1500 with the fancy Android Automotive thing and its frustrating me.  Note I'm referring here to the Google Maps built-in to the truck, not the Android Auto that is used when attaching a phone to the truck via bluetooth/cable.  Today I got in the truck and the little red dot appeared on my name and the message said it was updating the offline maps.  Ok, fine.  I get down the road a bit and notice the speed limit is not displayed on the HUD.  After I did my errand and started the truck again, the map showed a global view.  It would not show my local area.  I could zoom in to my area manually but it will not show my location.  When I click the icon for gas or food or just general search it says waiting for location.  I did choose the option to delete the offline map and re-downloaded -- and that was successful.  I so logged out of my Google account and logged back in -- did not help.  In short, Maps does not know where I am.  Maps was working fine yesterday.
The compass does know what direction I'm heading and the wifi streaming channels of SiriusXM are working.  That leads me to think the communications module is still working.  I say that because last year my previous truck also had and issue where the maps, data (streaming channels and offline maps), compass and myGMC App on my phone all stopped working and the cause was the communications module that failed.
Does anyone have any suggestions what this issue might be or experienced the same?
Don't use the Google map icon. You must be signed in and have an account, pay them. Use Google maps from you're Android
For others that run into this problem, its an easy fix.  In a nutshell, Maps “forgot” it could use my location although the setting said it was ok to use my location.
  • Go to the Settings menu of the truck,  not the Maps settings
  • Select Apps and Permissions
  • Select App Permissions
  • Select Location
  • Select Maps
  • Go to the bottom of the screen and choose Deny.  This is telling the Maps app to not determine your current location.
  • Now select the option Allow All the Time.
That’s it.  At this point I got a message stating it was downloading maps.  Let it finish and then Maps was able to see and track my location and the speed limit on the HUD returned.
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
