I ordered my truck and one thing I didn't order was the high idle switch and now I regret that. I did order the 200A alternator. Ideally I would like a high idle when I am charging my trailer lithium batteries through a 50A DC to DC converter.
Anyone add one of these to their gasoline powered trucks after the fact?
One thing I don't know for sure is if this was even allowed as an option on the gas trucks.
It is an option on gas trucks, uses cruise control to set it.  Sorry I have no idea about adding on to truck not ordered with it
I suspect it’s simply a software setting the dealer can change. It uses existing switches, so nothing to physically add.  The question will be whether they will do it on your trim level, but I don’t remember there being a required trim for that option when I ordered my 2021 with it.
You should be able to run a 50 amp dc to dc charger (drawing 55-60 amps) from the 220 amp alternator at low idle, though.
Edited by Another JR
Typo
Right now I have a 30A DC to DC and replacing with a 50A. Haven't tried it yet.
Does your truck have a 120 VAC inverter and plug?  I don’t know if they all have them but my mid-level SLT has a 400 watt inverter. To verify the capability to supply 60 amps at low idle, plug about a 300 watt load into that inverter to draw 25 amps while your 30 amp dc to dc charger is charging in bulk mode drawing 35 amps. You will be able to hear that the alternator has a good load on it. Put a voltmeter on the truck battery terminals and I’m pretty sure you will see that the voltage stays steady at just under 14 vdc at low idle.
While I have said I don’t think you would need a high idle switch due to insufficient alternator output at low idle for a 50 amp charger, if you plan to occasionally or regularly do extended charging of your camper batteries by idling your truck, a high idle switch is a good idea. It’s better for the engine to run at 1200 than at 500 to 600 rpm for extended periods.
    tblt44
    tblt44
  • Who's Online   3 Members, 0 Anonymous, 567 Guests (See full list)
    • There was talk over the last couple of years that the contract to build these trucks between GM and International would not be renewed.  International moved production of all their other trucks besides the companion CV model out of the Springfield plant some time ago when they opened their San Antonio plant.  That left Springfield only building the Silverado Medium Duty, International CV Series, and some Express/Savanna long wheelbase cutaways.  International also put the plant up for sale some time ago.  This all answered my earlier question as to why GM and International did nothing with these trucks since they were introduced, as they had basically become a market 'placeholder' with a finite life.    The Silverado Medium Duty/International CV trucks were interesting combination of a GM powertrain, electrical system, and K2XX Silverado cab with an International chassis that was supposedly designed for a step-van type vehicle they never produced.  They were manufactured in International's Springfield plant along with the IH MV series initially.  When first introduced, there was much talk that the Silverado Medium Duty/CV would eventually get a gasoline engine option along with other upgrades and GM and IH would work on a class 6/7 joint venture truck.  This was before VW bought Navistar out, after that happened no more was said.  Draw your own conclusions...   About the time talk started that the GM/IH joint venture was not going to be renewed, rumors started that GM would develop a new line of medium duty trucks themselves.  The story is the new trucks will be part of the next generation HD's due in 2028, and will still feature a 'straight rail' chassis design that the current medium duty has.  GM views this as a desirable feature that differentiates their truck from the competition.  A gasoline engine option is also expected.  As the current Silverado Medium Duty remains in production until September 2026 and there is still a lot of inventory available do not expect any official word for some time.   I believe GM remains committed to their successful partnership with Isuzu, and all the LCF models will still be available from Chevy Commercial dealers.  Isuzu is on the cusp of opening a new large plant in South Carolina and there is also speculation that this may result in new product for both Isuzu and Chevy Commercial dealers.
    • drive the truck back to the dealer and complain that the button works.
    • I have a 2026 2500 HD Ultimate. My phone app says there’s a software update available. It’s something about improved battery management and something to do with the running boards. I follow the instructions for the update but the “Check for Updates” option is greyed out in my settings menu. Has anyone else seen this? How did you resolve it? The help message just says “see your dealer” if the download doesn’t work. I’m just trying to save a trip.
    • Fuel mileage?  That's all how you use your right foot.  Exhaust will give you sound.   Stock exhaust 5.3 is 2.75" diameter piping.     If the truck is nice and worth putting some $$ into it, I'd go for a Corsa catback.  I had one on my 2019 old body 5.3 and it was just perfect.  Zero drone, just driving around and cruising on the highway you'd think it was stock, but when you opened it up it was like a Camaro with the factory dual mode.  Corsa bumps their catback to 3in diameter.
