I currently have 85,000 miles on the stock shocks and starting to leak. Time for replaceing.  When replacing is it necessary or recommended to replace the front springs? I'm leaning towards keeping the springs as the truck has seen almost entirely on road use, but could be persuaded if there's a real reason. When compressing the springs, are the Parts store rentals ok / safe, or just take the entire assembly to a shop and have them swap it out?
Also, other than the adjustable height, any noticable differences between the biltstein 5100 vs 4600?  Truck stays on road most of the time and already has a 1.5 inch level so would be leaving it on the lowest setting, thus leaning towards 4600 but not a fan of the ugly yellow.
Skip the bils... rough ride and not worth it imo.
https://eibach.com/product/E60-23-006-03-10?epsid=2260
Keep the factory springs if you want to save cost. Otherwise get their springs.
***Get a new top cap\ mount and take everything to a shop and have them assemble.
***No compressor an auto parts store has is safe to compress these truck springs. The truck springs have way too much force for the compressors to safely compress our truck springs. Just don't.
They all bent and one flew off when I did my bils swap.
Edited by Snowcamo
Wording
Sorry, I have to disagree, I went with the Bilstein 5100s all around.
On my 5 1/2" lift, it's never ridden any better, soaks up railroad crossing tracks with little issues. I ,also, have a rear spring lift which makes the rear even stiffer but the 5100s dampen it well.
Just my opinion.
Based on my experience, I think the 4600 bilstein allow more motion than the 5100, this is contrary to internet wisdom that says they are exactly the same.
I replaced the factory Ranchos on my 2015 Z71 with "standard" model 4600's all around (stock truck with no lift, lower, or front level).
The difference in ride quality was AMAZING ....
Same here with my stock 2018 All-Terrain. 4600's on all four corners and I do not regret that decision one bit.
To follow up on this, I ended up going with 5100's. I was going to go with 4600 but suprisingly the fronts are nearly non existant or anywhere to be found. Checked numerous on-line retailers and local parts stores and sold out everywhere. No idea why.  That made the decision pretty easy with the 5100's. Got them for a decent price at Shock Surplus, all four for $475. Haven't installed them yet, going to do the rears myself but take it in for the fronts just because compressing those springs scare me. Once they get on I'll let you all know what the ride quality opinoin is.
  • Like 4
    RyGuy43
    RyGuy43
  • Who's Online   0 Members, 0 Anonymous, 473 Guests (See full list)
    • consider doing electrical testing?  I would guess some power or ground wire/connection has a problem.   alldata.com has wiring diagrams, connector pinouts and diagnostic procedures you can use to find where the problem is.
    • can you tell if the reader is actually trying to get codes, and the pcm is reporting none, or is your reader just silently failing because it's not communicating with the pcm?
    • Any joy with this truck seems to be short-lived.   The CEL for P0172 ("bank 1" too rich) is now "intermittent".   I'm not sure where to check, or re-check, and my energy to keep chasing problems with junk is wearing thin. The P0172 seems to set as I'm coming to a stop, completely off the throttle, when fully warm. At least, that's what it's done the 3? times it's set.   Everything appears normal on the scanner EXCEPT long term fuel trim. There's only one bank on this vehicle because it's an OBD 1.5 with only one upstream O2 sensor. At idle, it's around -16.4% and will dip to -18% occasionally at idle or off-throttle. LTFT approaches 0 when throttle is held at 2500rpm. Short term appears normal, much closer to zero all the time. The LTFT tells me the engine is running rich at idle but compensating at higher load. But, why?   The EVAP purge valve doesn't appear to be leaking/sucking fuel vapor continuously. Is it sticking just as I come to a stop and the engine is choking on fuel vapor and sets the P0172? But that doesn't explain the persistently negative LTFT. Disconnecting the purge valve doesn't seem to make any difference.   I suppose that leaves another dang issue with the fuel injector. A leaking fuel pressure regulator, a new leak in the spider, or a leaking fuel injector/poppet valve I didn't see, or a small crack in one of the spider legs.   The vacuum line leading to the fuel pressure regulator doesn't have raw fuel in it. It doesn't even smell like fuel when it's pulled off, not until you suck air through it, then you can tell it leads to a fuel component. I'd consider that normal? Nothing is signaling this is a FPR issue from the outside, at least.   The oil smells like fuel but it's not building volume. I've noticed most oil in most engines smells like fuel to some degree so it's hard to say if the smell is an issue or not. Or if the engine just still smells like fuel because the crankcase was full of it a few hundred miles ago. But it's been changed twice since that original issue of the leaking fuel line dumping fuel into the intake.   Patience is running very thin. Every win seems to be accompanied by two steps backwards, or another issue that leads to removing at least the top half of the intake manifold. Enough! LOL
    • First off you mentioned "Toyo Says" and then gave the pressures 45/50, was this some person at the tire shop that pulled those numbers out of his head ?   Now of course I can't know your exact axle weights front and rear, however I have much the same pickup as yourself other than not knowing your starting weight as per the pounds the truck rolled out of the factory at due to the options yours did or didn't come with or what you have added beyond the extra tire weight. The correct way to know 100% where a person is at is by weighing each axle with the typical weight the vehicle is driven with and that means taking into account passengers and making sure you figure in a full tank of fuel and a little grace for whatever you may put in the bed "groceries" !    I am looking at and not that it really matters as all the tire companies use the same charts anyway, but I am looking at the comprehensive Toyo tire chart in the section that your tire falls under and I know it sounds confusing but your tire is not an LT metric tire like your factory tire but instead because its a standard inch measured tire its under a different category called an LT floatation series tire. That makes a difference as LT metric tires they don't want to see run below 35 psi at highway speed where as with the LT floatation series it can be run down to 25 psi on the highway as long as the weight on the said size of tire is agreeable with or less than that minimum 25 psi. It blows many people away that how is this physically possible, an empty truck for one thing and larger tires with the same size wheel diameter have a lot more air volume so they can carry the same weight as the smaller tire with less air pressure.    So my truck, I have the stock 275/65R20 wheels and tires and I have a bit of weight in the box with a bak flip cover and a rubber bed mat and some tools and spare gas. The front of my gas truck weighs a bit more than some trucks of the similar spec due to double batteries and alternators. However with full fuel and just me in the truck I am weighted such that I can run 40 front and 35 rear and so that is what I have done since day one.    If I base your truck at or slightly below the weight of my truck, in theory with your tires going by the tire chart you might be right around a minimum of 30 pounds front and 25 pounds rear. Of course that would hit pretty much minimum cold inflation pressure one could run with that tire size and a near empty truck. If you have access to an accurate weigh scale to do individual front and rear axle weights I would suggest you do that and make sure your topped up with fuel and whatever else in the truck before you weigh it and then you will have a great starting point to work off of and figure out what your bare minimum pressures are you can safely run. If you do much in the way of hot weather high speed driving, bumping up a bit for a safety margin is never a bad idea but just depends on what type of driving you do. I will include the Toyo chart and the floatation series sizes start on page 31. Without a doubt at these pressures I am speculating at minimum wise for your truck, it would most certainly ride very different then it did when you were using 55 lb front and rear.     https://www.toyotires.com/media/pxcjubjs/application_of_load_inflation_tables_20200723.pdf
    • Take an automotive stethoscope to the vacuum pump. Iirc those tick as well.
