2018 Z71 4WD with a regular cab/short bed config.
It's llowered 3/5 ish and I don't think I can go over the axle anymore.
Can anyone recommend a nice, low drone, cat back that exits in front of the back tires?
I typically use Magnaflow on most of my vehicles, but I'm not seeing a "front of the wheel" option from them.
Thanks in advance!
first, "Why lower a 4WD truck??, Anyway, I have a 18 'Rado, lowered 4/7" and I did Long tubes and a custom built 2 into 1 3" exhaust w/fact cat's all the to the rear, still plenty of room over the axle.
All wheel launches, brother.
I'll have to get under the truck and see how close I am instead of guessing, but honestly: I think I just like the side exit better. (for me)
Some of the fastest trucks around a lowered 4WD Ford F-150 single cabs, the combo that works and will go fast.
On 7/9/2024 at 3:19 PM, AZ_SS said:
Thanks dude. Do you mind if I ask what it's costing you for them to custom Fab the exhaust?
35 minutes ago, AZ_SS said:
I am re-using one of the XR1s but the cost is $600.
Thanks man
I assume that's from the y pipe back?
Having it done tomorrow, should be able to upload some pics.
That'd be great. Appreciate the update!
8 minutes ago, AZ_SS said:
No problem.
Looking good, dude!
How low are you?
Any room to turn out in front of the back tire or does it have to dump under the truck?
The rear has a 4" drop. There is room to go out in front of the tire, he said there is probably room to go over the axel if I change my mind.
    lingyuair
    lingyuair
  • Who's Online   2 Members, 0 Anonymous, 912 Guests (See full list)
