If anyone has seen my previous gen thread:
Here is a 2019, the same Dyno shop has posted this week.
Description shows "modified exhaust system" and "oversize over width tires/rims"
I don't believe these numbers for a minute. You should get yours tuned and let us know if this is legit.
Exactly. These 5.3 trucks put down nearly 300hp to the tire when stock.
If their stock dyno run only did 213, they have no idea how to dyno a truck.
I like how the torque peak between the 2 pictures went from 4,000rpm to 2,200rpm. Ain't no way a 5.3 or 6.2 is making over 400 ft lbs at that low of rpm without some superhcarger setup.
There's definitely some misleading and horseplay on these.  Also its a 2019 old body truck, not a new body so "technically" this thread belongs in the 14-19 section 😉
213hp on the baseline?  I had my 2019 old body tuned back when I had it.  It baselined a peak 267hp.  Most every other baseline I've seen of a 14-19 5.3 baselined somewhere in the vicinity of 250-280hp, depending on wheels/tires and I'm sure differences in dynos.
This shop seems like they are just trying to justify whatever outrageous price they are charging people for their services.
Sorry about that. I didn't realize until I went back to confirm any modifications. I posted in the 2014-2018/19 section after that.
^^ here's the link
Edited by COP TZR
I have a bet in writing with the shop owner. Unfortunately he could not pay for another deal so I have not found the free time or interest to donate to this pissing match. I use other Dyno shops in the area. Unfortunately I had to deal with this shops claims after a mustang club Dyno day they recently held which took me back to their FB page and the b.s. rabbit hole...
I posted this on the forum to confirm I'm not crazy thinking the numbers are being scaled down for baseline and scaled up for final.
Thank you everyone for the feedback.
Edited by COP TZR
    • There are probably a few threads talking about fuel mileage but this one seemed to fit the stats I have seen based on my typical local driven route but with different outcomes based on different seasons/temperatures. I have a few hundred pounds of items that consistently ride on the truck at all times such as a bak flip cover, rubber bed mat, tools and extra fuel so I would be something over 8100 lb without me in the truck. All these examples are based on a 100 mile round trip to a town plus running around town so maybe 110 to 120 miles in total for a trip. Using regular fuel and I assume it always has some ethanol in it but don't know the percentage they blend in. Also speed wise I am going at 62 mph and non aggressive driving although less speed yet if its crappy winter condition roads. I am going by an initial reset of the computer generated fuel use numbers averaged over a couple of thousand miles or so for each weather/season so they may be more optimistic then actual hand calculated numbers. Basically this is painting a picture of doing the same drive but seasonal conditions and temperature being the major variable to the end result. Oh and although I am in Alberta Canada, I am converting it to miles per US gallon so there is no confusion.    So winter time it gets cold here, no real surprise there and the roads can be clear at times but also often have packed rough snow or are are driving through loose snow ( they do a poor job of plowing the highways ) and yes this includes the extra idle engine time due to trying not to freeze ones butt off. 12.7 mpg is what I was getting during the winter months on average.    Then during the spring when it was around the freezing point and the highways are clear of snow, I was getting around 14.25 mpg.   Summer time, I have been getting around 15.15 on average but certainly some of the trips showed quite a bit better fuel mileage, so much depended on how much or little I had driven around town and number of engine restarts after sitting for a while at each location. But stating a best fuel mileage trip to town pretending that is what the truck gets on average is fooling ones self for sure !.      As I said in a different post, I had driven a 645 mile trip over a couple of days stint to a different destination then these other daily to town examples above, and was done during the summer with nice weather and not bucking a head wind, also keeping at 62 mph and its a rolling landscape type highway drive ( this isn't southern Alberta or Saskatchewan flat lands ) Hand calculated fuel mileage in this case though and it came out to 17.65
    • 2024 Chevrolet 2500 HD Custom 6.6 Gas Canadian built Truck  I tried to search for my previous thread on this topic but cant find it so my apoligies  for starting another one    #1   Since we have owned our truck purchased new it has this strange noise after using the remote start function  you press the remote start and you hear it start but right at the end of it starting it almost seems like it wants to start again after the truck is running .   There is no gap in time it is right at the end of the start . Almost sounds like when you have started a car/truck and its running and then you try and start it again and you get that grinding noise ,sort of     #2  You can only hear this if you are standing outside of the truck and near the truck  you cant hear it when you start the truck from inside  the cab . So it may very well be happening when starting the truck that way as in normally    #3   This only happens when it is started after sitting . For how long I don't know but it happens after sitting overnight for sure and it wont do it if you stop the engine after starting and then start it again  I have had it in to the Dealership before concerning this but they did not have the truck  when it was cold to hear it . Now its back in the Dealership left it overnight so they could possibly hear the problem . They said they tried and nothing happened . Well they did not know what they were listening for . I started the truck remotely and BINGO it makes the noise . Oh that sounds weird they say . We need to look into it ! I have left for this week at the Dealership    Does your 2024 2500 HD gas do this ?  Any of you fellas care to take the time and trouble to film this operation from a cold start  so I can hear what your sound like  Really  would like to know if this is anormal sound  Thank You Fellas !!
    • 2026 Z71.  The other day I was backing a trailer into the barn.  The alarm was going off just because the trailer was in the field of the warning sensors when you get too close to something.  For some reason now the warning alarm doesn't work anymore.  It used to go off when I was just normally backing my truck into garage.  I still have the guidelines in the back up camera.  Is there a button or something to push to turn the sound/Alarm on and off?  I have the touch screen in this truck.  There isn't a "P" on the dash except for the parking brake.  I can't find anything in the touch screen under settings or vehicle.  Thank you in advance.
