I was driving my 2018 Silverado (~75k miles), was driving at low speed merging onto highway, RPMs suddenly dropped to zero, got no acceleration from the throttle, pulled over, turned truck on and off then ran fine for another 50miles before it happened again at a red light, no lights on the dashboard appeared, I want to assume it’s the transmission but any idea what else it could be?
Not following the zero RPM's, did the engine die? Sounds electrical, bad ground, bad battery..... Any CEL's present?
Edited by JimCost2014
RPMs gauge dropped to zero, complete zero, as if the engine just shut off yes, but everything electronic was still on (stereo/ dashboard), no CEL’s present, I cleaned the MAP sensor, maybe something electrical?
Take it to a parts store and have it scanned, not all failures turn the CEL on. you may need a scanner that records so you can see the data when it occurs. Trans codes may not turn the CEL on but are still stored
    • It was never mandated.  Ever.    Automakers were incentivized to install it by getting CAFE credits to help with their vehicle fleet fuel economy scores.  They were being handed money/CAFE credits to install it.  Which is NOT a mandate.       The current admin removed the incentives that were behind them installing it.
    • I went another direction after losing a trailer tire, thanks to not being able to access air at ANY of the 5 gas stations and garages I stopped at prior, with a Toyota Tacoma onboard, 50 miles from the Canadian border. They were either out of order, access was blocked, or the hose a few feet too short and I couldn't get any closer without risking damage to someone's property.   https://postimg.cc/gallery/X5QJ55w
