The website doesn't say they are different models.
The heat units are the same, there is software built in that allows it to work with 7" manual AC screens. 8" AUTO HVAC and 8" AUTO DUAL HVAC.
Update:
I have installed the unit after a few weeks of receiving it. I will admit it's not completely seamless, but depending on how you use your infotainment, the slight hiccups with this unit may not really affect you. First its an extension of your infotainment, it does not replace it. I had initial problems due to my own error in setting it up. Luckily, I purchased it from Autotecpro, so I was able to schedule a Zoom call and go through how to set it up for how I use my system. For example, I stream 100% of the time whether it's Spotify, Pandora, or SoundCloud. I never listen to Am FM or even Sirius. Another hiccup is in certain apps. Spotify doesn't stream video yet like it does on my phone, but I got over that. Youtube and Netflix, Hulu works fine. Some may find it fun to create cool and custom wallpapers, but I found one and just left it alone. Bluetooth calls and sound all seem unaffected. overall I like the unit and it helps update the interior of the truck
  • 3 months later...
I have one available for sale if anyone in the VA/NC/SC area is interested in purchasing one of the T-style units for their 2019-2022 AT4/Denali. I did not get a chance to install it before I moved on from the truck. Let me know if anyone is interested.
On 7/31/2024 at 1:03 PM, bluemonstercali said:
Does anyone know if aliexpress,Aucar,Autotecpro are all the same unit? they all look the same but have slightly different price tags.
Checkout www.radioeditauto.com for authentic AuCar units with a US connection as they are based in FL.
Did you happen to get the factory settings code. I have asked support they will not give it to me. I need to access to fix the lip sync on video
  • 3 months later...
Im highly highly intrigued by this. I looked around but haven't seen anyone installing in a 2025. I assume it would be the same as the installs others have posted?
The 22.5 trucks are Global B architecture and I don't think these kits work for those. LT trims and above already have the big fancy screens.
