Hey just got myself a 2019 sierra 1500 sle, It only has 40000 kms.  Im
wondering if there’s any issues I should be looking for it has the 5.3 and the x31 package. I’m coming from a 01 Silverado that I put 420000 on so it’s a massive upgrade.
Also wondering what’s the best product to polish the rims
Those wheels should have some sort of clear coat on them so I would pass on any "polish" like metal polishes.  You'd treat them like a painted surface.  Hit them with a good wheel cleaner, then you could use anything like a wax or ceramic coating on them.  Coatings will ensure they stay clean and protected longer.
Edited by newdude
5 hours ago, silveradosid said:
if it has an 8 speed transmission, take it and get the fluid changed to the new fluid
What is the new fluid? First I’ve heard of this
Since 2016 when the 8 speed was being used, GM had changed the fluid 3 or 4 times due to issues with it being hygroscopic.  The current fluid is Mobil 1 LV ATF HP Synthetic, GM # 19417577.  Has the blue label on the bottle.  This fluid came out 2019 or so, and was being put into trucks by 2020.
If you have what they call a rumble strips shudder between 25-80mph, changing the fluid out using that fluid will solve the shudder.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
