Hi, My rear differential is GM (SU8 with G80 positraction limited slip & GU6 3.42 ratio). I am about to change the differential fluid. Is ACDelco 10-4122 (GM 19368514) 75W-85 DEXRON Low Viscosity Gear Oil right one? I’ve read some say G80 needs LS additives or others say “no”. I think G80 doesn’t need additives but please confirm it for me. Thank you.
Never put LS additives in a G80
G80 is not a 'positraction limited slip'.
G80 is a locker.
Edited by redwngr
Please educate me further. I can’t play YouTube you linked for some reason now. The description of G80 I got from my dealer is “axle, rear, positraction, limited slip” What am I missing? Thank you.
It doesn't use clutches to lock the wheels when it loses traction. It's a mechanical locker that uses weights to throw out and engage the locker. You can use the google if you want to read up on how it works.
Regular synthetic gear oil is all that is required.
As mentioned you don't need additive for the fluid. I will say I had a hard time finding the correct viscosity for the diffs that didn't have LS additive added to it from the factory. I put 75w-90 into both the front and rear diffs on my old 2014 and it worked just fine. I ran it with that fluid in it for 3 years and had no problems with chatter and the locker worked the same as it did from when I bought the truck used.
I could be wrong but I don't see any problem using fluid with the additive on a diff that doesn't require it. It's if you use normal fluid on a limited slip diff that you have a big problem.
If you add additional friction modifiers to a G80 you'll induce issues such as improper engagement etc.....
    Afennell19
    Afennell19
  • Who's Online   2 Members, 0 Anonymous, 955 Guests (See full list)
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
