Hi, My rear differential is GM (SU8 with G80 positraction limited slip & GU6 3.42 ratio). I am about to change the differential fluid. Is ACDelco 10-4122 (GM 19368514) 75W-85 DEXRON Low Viscosity Gear Oil right one? I’ve read some say G80 needs LS additives or others say “no”. I think G80 doesn’t need additives but please confirm it for me. Thank you.
Never put LS additives in a G80
G80 is not a 'positraction limited slip'.
G80 is a locker.
Edited by redwngr
Please educate me further. I can’t play YouTube you linked for some reason now. The description of G80 I got from my dealer is “axle, rear, positraction, limited slip” What am I missing? Thank you.
It doesn't use clutches to lock the wheels when it loses traction. It's a mechanical locker that uses weights to throw out and engage the locker. You can use the google if you want to read up on how it works.
Regular synthetic gear oil is all that is required.
As mentioned you don't need additive for the fluid. I will say I had a hard time finding the correct viscosity for the diffs that didn't have LS additive added to it from the factory. I put 75w-90 into both the front and rear diffs on my old 2014 and it worked just fine. I ran it with that fluid in it for 3 years and had no problems with chatter and the locker worked the same as it did from when I bought the truck used.
I could be wrong but I don't see any problem using fluid with the additive on a diff that doesn't require it. It's if you use normal fluid on a limited slip diff that you have a big problem.
If you add additional friction modifiers to a G80 you'll induce issues such as improper engagement etc.....
    B07
    B07
  • Who's Online   2 Members, 0 Anonymous, 880 Guests (See full list)
    • Missing pieces of the Assembly   Detergency vs Solvency   Not the same thing. Detergency is the mechanism that surrounds solid particulates preventing amalgamation. Usually accompanied by a Dispersant whose job it is to keep those encapsulated particles in Suspension. Solvency keeps things that can be dissolved in solution.    Salt is a solid that can be dissolved. Pepper is a solid that cannot be dissolved. A detergent/dispersant is effective on pepper but a solvent is more effective on salt. As long as the solids remain in either state, dissolved or dispersed then they can be be removed with the oil upon change.    How many wranglers does it take to herd cats? Depends on how many cats your herding. How much sponge does it take to soak up water? How much water is there to soak up? Point is most oil blends start with some herding ability and next to zero sponge and recently even fewer wranglers are being sent to do the same job.    So you start with a dozen cowboys and zero cows but at the drive progresses you pick up cows along the way, but not cowboys. At some point you have more cows that the wranglers can handle and some leave the herd. Deposits. And the API has an acceptable number of cows they are willing to let loose. In the ideal world zero is the right number for he rancher but to the butcher....a few lost is fine. This cow is beat to death. Let's move on....   Solvency isn't something oils on the Walmart shelf care about AT ALL. Problem is, you motor does. Fuels driven varnish sticks rings and only a solvent can keep them in check. The bet is that the solids driven portion that plug the expander rings and the oil drain backs and VVT screens and AFM screens will be an issue long before varnish is. Not that it wont be but if they market well enough the consumer can be kept ignorant enough to either believe it is "normal" (A quart in 1 or 2K is normal) OR is kept at bay longer than the first owner is likely to hang on to the unit. Solvency cost money.    Now the OEM's have John Q. Public buffaloed into the belief that the number cows accumulated along the trail is a known and predictable CONSTANT. It isn't. Nor is the rate at which they crossed paths with them. Only the number of wrangles is constant. Or was. Each new generation of oil sees fewer and fewer of them.    So what happens when the number of cowboys is lower (lower TBN) with each seasons trail but the trial is longer (OCI) and the number of cows along that trail continues increase? (Conditions that promote deposits).    For awhile the blenders were on to something. Better bases are harder to degrade (fewer cows) but that was overtaken by a longer trail (OCI) and improved breeding (More cows) while continuing to reduce the cowboy staffing levels (TBN/Aniline #).    Marketing has been successful. We've fired most of the staff, cows breed line bunnies, the trail is ten times longer and we've convinced the boss his ranch is in better shape that it ever was.    That kids is just the cleaning side. The side few pay attention to.
    • Looking for this part for my truck. They don't sell just that one piece and to get it you have to pay over $100 even used for the whole air tube. The piece the hose clamp snaps into that is held on by the screw and nut. If anyone has access to one please let me know.
