I owned the first generation of the 1500 duramax and loved it. It wasn't my daily driver, so I kept getting a check engine light. My guess is and from what the dealership told me, is that I didn't drive it enough to have the soot burn off. I don't currently own the truck anymore, but I am thinking of getting another one after my lease ends. My question is, how often and how long does the engine have to run for the system to do its thing? One service tech told me to turn it on daily for and let it run for about 20 minutes. Any info would be greatly appreciated.
idling a modern diesel is a bad idea (builds soot really fast). If you drive the 3.0l around town it will regen more often but the 3.0l is less sensitive to non-highway/light load than the 6.6l is. A normal regen takes about 10 min on the highway. If you drive at highway speeds or loaded it will likely regen based on mileage or time and not soot level. One of 3 things will trigger a normal regen on a GM. Time, miles since last regen or soot level. Just an FYI but the GM diesels will stop a normal regen when the engine is idled in park and restart when in drive and moving again.
Edited by Jay P
Sounds like that person at the dealer doesn't understand how they work.
No need to do anything 'daily' to keep it happy'.
If the exhaust filter has soot problems it will give a 'keep driving message', not a check engine light.
As @Jay P pointed out the 3.0 only takes about 10 miles to complete a regen and if a regen is interrupted that's ok too -- it will finish the regen when it's driven again.
Unless it is giving 'keep driving' messages there is zero reason to do anything special.
I never got that "keep driving" message. I once got a "power reduced" message and it wasn't even a year old. What it also used to do was, sound like a Cummins with a lope. But I'd just shut it off for a while and it wouldn't do it. Any idea why it would do that?
Like most engines, but more so with diesels, they don't like short trips.  If I need to run up the street a couple miles to the grocery for my wife I take one of our cars.   I generally don't drive the truck unless I know the engine is going to get fully up to temperature, which depending on weather is generally about 5-10 miles.  Our truck isn't a daily driver so it sits in the driveway for several days in a row without moving and I've never had any issues with soot or regens.  My DEF usage is also spot on to what the manual says - generally less than 1 gal. per 1500 miles.
The only other vehicle I have is my work truck, but I don't like using it too much because of the tools in the back. My 3.0 was the first gen engines, bought it brand new in 2019. I will be getting another one, now that I've gotten some info on how they work. Thanks
    • I went through again with a test light and everything checked out.    I suppose it could be the MAF itself but I've tried 3 different sensors, 2 of which were in running vehicles previously (the one in this truck, and the one in the donor truck), as well as a new one I picked up from NAPA. I would just be surprised if all 3 were bad.   EDIT/UPDATE: I swapped in the MAP sensor that was originally with the 2010 PCM, that made the code for map sensor voltage high Go away, and the map sensor seems to read normal with key on engine off (14psi or so), but it still doesn't run and does the same thing as before.
    • In addition to a cell or wifi connection, the infotainment needs to be enabled to download software updates. That's a toggle within the system settings.   But...if the truck was prevented from receiving updates in a past life, missing a bunch of updates may mean it won't go back and download all of those because they're not available or the system is too far out of date.   If a formal recall depends on a software update, the recall for that truck remains in an open status until it's applied. The dealer would need to apply the software update in that instance.   Most updates downloaded and applied via the infotainment aren't recalls/safety recalls, they're enhancements and usability fixes which aren't critical.
    • Recently I've been getting a message, "New Brake Pads Detected. Reset Brake Pad Life?", But I haven't had the pads replaced and the truck only has 28,000 miles. The Brake Pad Life shows Front 64% and Rear 79%. I select NO to resetting the brake pad life and the message goes away but comes back at the nest restart.   I stopped by the dealer and was told that it sounds like a software glitch that would require reprogramming. Even though I have the extended warranty, they tell me that reprogramming is not covered unless a module was actually bad and needed to be replaced. Simply reprogramming is not covered. So, they want $200.00 just to diagnose the problem. If it turns out no bad module, another charge on top of that to do the reprogramming. If the cause was an actual bad module, everything would be covered under the warranty.   Just wondering if anyone else has had this problem. Should this issue be covered under the warranty?   Thanks
    • NHT is diesel only, correct.     The GVWRs for NHT on 3/4 ton bring them to the same numbers as many of the 2WD 1 tons.  A crew 4x4 standard 3/4 with NHT is 11,750lbs, a 1 ton same cab/box/4x4 is 12,100lbs.     Hubs and hub bearings are the same for 11.5" and 12" axles.  Housing, diff carrier and ring/pinion are larger for the 12".   All gas use the 11.5" axle, 3/4, 1 ton and 1 ton DRW.
    • Yes, I connected it to my home wifi.
