My engine overheated while towing about 2000 pound trailer. 130k miles on the truck. Have used Mobile 1 oil for last 100k miles. Oil always changed every 3k miles. Thought failure might be water pump or thermostat as high temp light went off while towing. I pulled over right away and let it cool down. Truck was down about two quarts of Antifreeze after it cooled down.
Once towed back at the shop, mechanic found a head gasket issue. White smoke coming out tail pipe and coolant bubbling and now discolored.
This was my dad's truck so I want to keep it. Body in great shape. I would like to try the head gasket repair. Mechanic pushing for a crate engine replacement. Would like to keep costs to $2500 or less.
I see on the Forum that it's quite common for this failure near cylinders 3 and 5 in the head gasket.
Am I wrong to first see what the heads and block look like?
My thee options are one replace head gasket and rebuild, two find a used engine with unknown issues, three replace with a rebuilt crate motor this option around 5K for this option.
Mechanic says 8 out of 10 head gaskets issues end up with another engine either used or rebuilt.
Last what info do I need to spec a used or rebuilt engine if I need to go that route.
Would like to here the pros and cons.
Welcome to the Forum! I would determine which cylinder is leaking before tear down then pull it apart If the gasket failure is not apparent then have the head checked by an automotive machine shop and check the cylinder wall for hair line crack, Is there coolant in the oil? Coolant on the bearings is not good so if it ran for any length of time with coolant in the crankcase a crate motor may be the way to go, That said it is a very easy engine to work on but 35 years of New England winters there"s bound to be corrosion issues with the exhaust bolts, oil pan and bolts etc. Is it a real 2500 (8 lug) or 6 lug? How many miles? Where in Mass? Intake gasket failure is a much more common failure that leaks coolant into the crank case. I had an 88 with typical problems for a 300k mile truck , Loved the truck. Check the price on a new GM engine before buying a rebuilt
Edited by richard wysong
Thanks Rich. 130k miles. Had the Manifolds changed out earlier this summer. So that part will come apart. It didn't see NE winters for 20 years. Dad was a snow bird. That's why frame and body in great shape. Plus he used to treat the frame from rusting. I think there is coolant mixed with the oil. As oil level is above the full line. I wouldn't think the coolant would mix with the oil? It looked all one color on the dip stick. Didn't see any water.  I'm in central Mass. This happened 10 Nov. Not easy to find a shop down here to do this kind of work anymore.
I saw one post, where a  member, did his tear down at 130k before he had an issue. I guess he made the right call. I'm very mechanical, but have not done a complete engine tear down. I do not have a covered garage to do the work. Where on engine is the engine number marked so I know what I may have to replace.
Why a GM new motor over say a Jasper or JEG motor rebuild? Curious. Thanks for the reply.
I bought a used truck years ago nice low miles. Did my usual fluid change and noticed no antifreeze in the radiator so I flushed it. A week later it started to get warm. Turns out I flushed out bars leak. I don’t know if it had a head gasket problem or cracked block. I added block sealer antifreeze. It worked. I was doing recycling at the time so it pulled some loads. I would give that a try before replacing an engine. It could buy some time.
Engine number is on the right front block deck just in front of the head but you shouldn't need that to get parts, Small block Chevy parts are fairly universal, Pull the oil drain plug and see how much coolant comes out before the oil. Does the oil look like chocolate milk? Brand new Targetmaster GM engines used to be much less expensive than a rebuilt but it has been years since I bought 1. They come with new oil pan and valve covers
Replace the headgaskets and send it.
Have a machine shop check the heads if you really want them to. They can hot tank them and deck them to make them fresh for a cost.
The last thought in my mind is to replace the engine. You didn't boil this thing down and headgasket failures are fairly common to the 350 engines. If you do the work yourself, I see no reason why it can't be done for under $600 in parts. Gasket kits are cheap, new head bolts are cheap, oil and coolant isn't that spendy. The only big cost would be if you send the heads out to be cleaned and checked.
Cleaning the block and preparing the work is easy. Lots of ways to do it and it just takes a little time.
  • 4 weeks later...
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
