So I've been battling some pretty bad electrical issues for about six months in my 2018 Silverado 2500 duramax. First happened one night at work where it started then immediately showed service power steering. Service stabilitrak. Service trailer brake controller. Also noticed that I didn't have a gear shift indicator. Nor where my rpm or speedometer gauge working. I moved the truck a little bit and also realized the transmission wasn't working properly and shifting funny. Turned the truck off and tried to turn it back on and all the same service lights came on but this time it wouldn't even crank. Ended up disconnecting battery cables for a while. Then it started and ran fine a few days. I took it to a shop. They couldn't find an immediate problem so put die electric grease on connections and sent me on my way. Well I didn't see the problem again for a couple months. But then it all happened again. Same service lights. Check engine light. And bad shifting. Got it home and pulled the codes on it. U0073 u0100. Sent it to the dealer in town beginning of November. They looked at it and said there was a code in it for the bcm so they decided the bcm was faulty and replaced that. Then told me my truck was fine. I took the truck to our local Walmart 5 mins away went shopping and came back out and got the service power steering service stabilitrak. Service trailer brake controller. And two new ones. Reverse cameravnot working. And service 4wd. I drove back to the dealer. And by the time I got there the lights went away and it was back to shifting fine. They said they couldn't see anything wrong with it. Though it showed the check engine light again. I left it with them for a week. They drove it multiple times that week and couldn't get it to act up so I went and picked it up. I Read about a g218 ground and was hopeful that was my culprit. Pulled my dash apart to check to see if there was sound proofing between the ground nut and the metal and there wasn't so it all looked good. So unfortunately that wasn't it. We'll got home and hooked my scanner up and saw the codes u0102 u0121 U0140 b127e. While running the scanner on the truck running it went to all the service lights again. And wouldn't connect with the code reader at all anymore. Then I turned truck off. And couldn't get it to turn back on. Tried unhooking batteries. Waited a couple days. Still no luck. Ended up towing it to a shop beginning of December. We'll they started trying to diagnose it. Went by unhooking things and hooking them back in. The guy got to the turbo unhooked it and hooked it back in and got the truck where it was running fine. They called me and told me this and I said I wanted them to keep looking because obviously something is wrong making this keep happening intermittently. Well for the past two weeks they've been trying to get it to act up to diagnose it further. Which it's acted up for them. But not consistently to trouble shoot it. It's so very intermittent. So now I've just been very upset with my truck situation and starting to wonder if anyone will ever figure it out. Or if I bought a lemon. Both batteries on the truck at new as of may. And both test good.
Ishhh, sorry to hear about your problems. Any luck yet?
I had a parasitic draw, due to a faulty BCM. Dealer changed it out, and called me that they monitored it for 4 hrs, as few of the replacement were faulty from the factory. Sure enough the replacement had issues also. Got a second replacement the next day and it has worked fine since.
Maybe ask 'em to look at changing out the BCM again, and or ECM?
Edited by BNSF
There is an easy way to test for parasitic draw.  Look at this video.  Basically, you just check every fuse int he truck. Eventually you may be able to isolate it.
So I got the truck back at the beginning of the month. The shop determined the glow plug control module was the culprit. Replaced it and it's been running fine since I got it back
Thank you for all the time and information, as I'm dealing with these issues on my 2017 L5P cab and chassis truck now, it's quite frustrating, I'm glad to hear that you found your issue. Someone had broken the cell light out for the Check Engine light and the Glow plug Light prior owner. So I am going to assume we may share the same module as culprit. Going to send my Cluster to be fixed and CK the Glow plug module next.  Hope your still going strong since your fix last input. Ty Daryl
    • Of course actually engaging four wheel drive is step one or even daring to use a ramp like that with a two wheel drive and getting into a mess because of it. As to 4 low, these last few years if its a GM half ton it may not even have low range. A lot of the newer pickups have a lot lower first gear in an automatic transmission then they once did as it was common at one time for a gas engine truck or even the older diesels to just sit there and bog the engine due to the torque converter stall point and not enough torque was generated on reasonable traction to even spin a tire or get out of its own way up a steep grade and 4 low HAD to be used to get enough power to four tires to get them turning. These days traction control systems may hinder a vehicle in a situation like that although that means a tire or tires are spinning so in some ways the traction control can reduce wild spinning and anyone can correct me on that but I think some vehicles cut traction control off in low range ?.    By the sounds of it and you may have the proper equipment but if your responsible for helping vehicles out if they are not able to get out under their own power, I would say to be using a nylon tow rope or have one available so that one is able to give a bit of a run to help sling shot them some initial momentum as most tow straps are made out of polypropylene and impart way too much shock load if used to jerk a stuck vehicle into motion but are totally fine to use if going more from almost a dead pull with the tow vehicle and they are a lot less expensive to replace if damaged. That and some soft shackles to hook onto closed loop tow hooks on the truck your pulling as well as you having the proper shackle insert in your truck so there are no bad accidents with metal clevises joining things together or chain on the end of a tow rope or tow balls being hooked onto etc flying and causing damage or worse if it lets go. Its always a challenge pulling people because some are clueless and will over run the tow rope or strap and drive over it or that risk of ramming into the back of the tow vehicle so usually a few instructions are needed to clue in the driver of the stuck truck. Yeah ... have fun out there 😉
    • In their own words:    https://blog.amsoil.com/how-engine-sludge-forms-and-how-to-prevent-it-2/   [Quote] Synthetic Oil Helps Prevent Sludge Fortunately, sludge and varnish deposits are something that can be controlled. Using thermally stable synthetic base oils reduces the rate of degradation (oxidation).   Antioxidant additives further help reduce the rate of degradation. One of the most widely used is zinc dithiophosphate. Not only is it an excellent oxidation inhibitor, but it is also an outstanding anti-wear additive.   High-Quality Additives Fight Sludge Fortunately, it is possible to address many of the issues that occur after the initial oxidation stage. Additives, such as detergents and dispersants, help promote the suspension of contaminants within the oil and keep them from agglomerating.   Detergents, which are also alkaline in nature, assist in neutralizing acids generated in the sludge-building process. Antioxidant, dispersant and detergent additives are consumed during use.   To achieve maximum life expectancy, use a motor oil with high concentrations of antioxidant, dispersant and detergent additives.  [End Quote]   So quality base oil and then the last sentence above. TBN and ZDP levels matter. The one thing not covered was sufficient viscosity. Sad.     And yet we now have since API SN lower amount of them all with the only real change being a slight up tick in base oil selection. Along with lower concentrations of everything that makes oil work and lower and lower viscosity there is still an insistence on longer OCI's.    How low does the peanut butter and jelly level have to get before we say it's just white bread folded?    The new smoke and mirror treatment is the 'additives are INVISIBLE' to UOA testing with a health dose of TRUST ME.    I'm not picking on AMSOIL. This is coming from all of them. Every last one of them that abandon the low wear model in favor of the high mpg/EPA compliance model.
    • First off use it in the way you’re more comfortable. In working in off road situations most of my life I used 4WD low range very little. In most cases when equipped I used auto 4WD. If I wanted maximum control going up and down very steep terrain  I used low range. Especially if I was driving a diesel. Same with very rutted terrain. In very muddy or snowy conditions I wanted momentum so high range worked well for that. With gravel ramps with limited traction I would try high range first. I would want smooth even increasing speed if I was fighting traction. Low range could give you too much to the wheels breaking traction trying to move.
    • Having owned 4wd vehicle since the 1970s I find there are varying opinions on how to use 4wd, every owner is an expert in their minds.  IMO, 4LO is the appropriate gear and what I would use,  You have to feather the gas to avoid spinning tires and the lower the gear the better chance.  But like I said you will find those that think their method is best.  I live near a boat launch.  Yesterday there was a new Ford Maverick pulling out a pontoon boat almost 2x its size, they had no problems and they don't have a LO range.   True story. One winter day not long ago I was coming out of small town post office and there was a F150 4wd parked in front and was stuck foot deep snow ruts. I knew the lady so I asked her to put it in 4wd (wondering why in the middle of a 2-day snow storm she wasn't).  Her reply surprised me, "my husband" (the expert) told me not use that because it uses too much gas. She finally got unstuck spinning in 2wd which likely used more gas than not.
