Hello all. I need some help finding out what the sensor or whatever it is called is in the photo by the arrow. It appears to be loose and leaking. Even after a thorough googling session I can't find any description or part number for it anywhere. WTF! Gmpartsdirect doesn't show it and the one diagram I did find called it an engine oil pressure sensor which I don't think is right. Its a 2016 5.3L engine. Thanks for any help!
That I'm pretty sure is the camshaft sensor. The other sensor to the right is for the VVT.
Edited by CamGTP
From what I can find, the cam position sensor lives to the right of the vvt. (Can't see it in the pic) I'm starting to think the oil leak may be actually coming from that vvt plate gasket. Seems to many YouTube videos of that one. Still would like to know what the left one is though....
You are right. The right side is the cam sensor, the center is the VVT and the left side is for the variable oil pump connector. Inside the timing cover there is a harness that goes down to the oil pump itself.
