When it’s cold outside (20 degrees or colder) the truck starts and idles normally, but once engine temp gets to normal temp then  I come to a stop or slow down below 5mph the rpm’s surge/ or change and sometimes stall out. Once it stalls you hear a pop noise. I can raise rpm’s then it goes away but it will come back again. Truck has been to dealer 2 times already and they say it normal but I don’t think so. Not sure what to do because it’s getting annoying
-changed spark plugs at 48,000 miles
-transmission fluid was changed 45,000
- new air and cabin filter
- run 89 octane fuel
Not normal. The engine should not stall or misfire. Has anyone scanned this truck for codes with a proper scan tool?
Yes, this truck has been to dealer 3 times and they say it’s normal. There are no codes or anything in system. We cleaned MAF sensor, replaced all filters and even throttle body cleaned but issue still happens randomly
Did this start after plug change these motors are very sensitive to aftermarket or non OEM spark plugs. Did you put the exact OEM plugs back in? Amazon and some auto part stores are notorious for selling OEM knock offs. Check the connection to the spark plug from the boot could be loose make sure you feel the click. The problem your describing aftermarket plugs can cause this. Check to see if the new plugs are cracked very easy to do on the install.
Edited by Silverado4x4
The plugs were bought at GMC with OEM plugs and I installed them . I will inspect plugs but if the ceramic on plug is cracked it more would have misfire under load. Not saying it can’t happen at idle but it would happen more under strain or load on engine
you are going to have to hook up to a good scanner that can monitor all the sensors. when it happens something is not right and there is many things that can cause this to happen
I do have a solus plus scan tool I use but it’s hard to figure out what’s going on be I only have limited time from when it happens.
I do know when GMC removed my intake for warranty work they pinched #2 ignition coil wires and taped them up because they said they were still connected. but I still have no misfires on any cylinders. I’m wondering now if the #2 coil wires that were pinched are causing issue even though it may not be a big enough misfire to detect?
  • 11 months later...
Found and fixed issue
PCV line fitting was cracked on intake causing stumbling idle and stalling. Brought truck to dealer and told them to keep truck until fixed and got rental car for 4 1/2 weeks just for a PCV line. No issues now for 3 full weeks.
    LeeBob
    LeeBob
  • Who's Online   0 Members, 0 Anonymous, 1,390 Guests (See full list)
