I am looking at trucks simply because I’m looking for a relatively smoother riding truck and because it’s about time to trade in my current truck.
current truck is a 2023 f350 lariat single rear wheel. Been a flawless truck for me and it has a 23,000lb tow rating. So it’s been great when I was towing a little heavier but we’ve got several other trucks in our fleet now that can move our equipment around.
with a decreased need for heavy towing I’m looking at a 2500 Denali hoping it will ride softer.
with that being said I’m looking for feedback on several things.
1–will a 2500 gmc ride smoother than my current f350?
2–are there any common problems with the 24s? I hear people have been having oil cooler issues (mixing coolant and oil which is no good). Anything else?
3–level kits on these trucks seem to really ruin the ride with the torsion bar setup. Any decent kits to get 2”? I don’t want a 6” lift on 40s. But I do like messing with my trucks a little bit
4–I’ve also been spoiled with the fords and how easy it is to run bigger tires…..these square wheel wells on the gmcs don’t seem as big. What’s the biggest tire I can run stock?  My current truck is 2” leveled and 37s with plenty of room to spare.
thanks in advance for the advice. I’m not familiar with these trucks
You really need to go test drive them to see if it rides softer. Just because it says Denali on the side doesn't mean it will ride better, it's still the same heavy duty suspension under the truck. Most trucks will ride a little smoother with weight in the bed or towing, just your normal everyday driving with nothing in the bed will likely ride the worst. Mainly because the suspension in unloaded and the tires will have lots of air pressure in them which causes a rougher ride.
For sure a 35in tire will fit. The biggest stock tire is like a 34in if I remember right but I'd need to double check.
You didn't say if you wanted a gas truck or a diesel truck.
Diesel and of course trim level doesn’t decide stiffness in the ride. That’s why I put in the relevant information of f350 vs gmc 2500. Looking for that feedback from anyone who has been there and done that. Never had a GM truck before always had ram or super duty……that’s all.
They are both heavy duty trucks and ride like it. My '24 2500 does ride slightly nicer than my '21 F350 did though.
The main issue that seems to have popped up on various forums is 10-speed valve body failures.
I have no input on running bigger tires.
Yeah I’m seeing people experiencing nightmares with the valve bodies in these trucks. Wait times from GM in a lot of the cases I’m seeing seem long.
I always thought this ten speed was co-developed with Ford to some degree so it would be similar to the one on my current F350 (and it’s been rock solid).
That was the half ton truck transmissions. The heavy duty truck as I understand it was not co-developed.
the independent front suspension is much nicer than Ram and Ford imo.....had 4 of these and no issues so far, low miles too....the digital steering on higher trims is a plus vs LT and below......havet lifted it but craking on torsion bars will stiffen it....there are coilover kits available but $$$....
any truck can have an issue so just depends
If you must go to GM I would go with a 25' to hope I escape the 10l transmission issues. I have been looking at the super duty's myself and I didn't find the ride to be that much harsher then my 23' Sierra 2500. I would test drive one to see, If the Ford has been flawless maybe switch to a f250 instead.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
    • Just don't turn the steering wheel as much?
