Everybody knows Chevys love fully advanced ignition timing!
How does a Guy change ignition timing?
Yes, I do Listen to these guys in here, this is all they do is GM stuff.
No ya can't move the distributor around anywhere ya want, as you read in an earlier post the Crank shaft position sensor is monitored against the relative position of the Camshaft sensor.
No ya can't move the distributor around anywhere ya want, as you read in an earlier post the Oil Pump tab fits together (like a screw driver to slotted screw) with the Oil Pump slot. So in order to change the timing you need to pull the distributor and turn the pump with a screw driver to a point where an educated guess matches the Pump shaft, Camshaft Gear, Distributor and timing set point. So a Guy really needs to know what he is doing here or as I suspect in your case the Oil Pump shaft will be crammed down inside the pump and destroy it.
No ya can't move the distributor around anywhere ya want, as you read in an earlier post the ECM (ECU) constantly monitors where the timing is to be set, not the other way around where the Back Yard Mechanic tells where to set the ignition timing and when the Back Yard Mechanic sets the timing which violates these ECM parameters then the ECM Rats a Guy out, throws a code and turns on the "CHECK ENGINE" Light.
Once the check engine light is on then the ECM parameters are wrong and other systems as in Transmission shifting gets all messed up. Did I mention miss fires?
No, that's why we are here.
Edited by txab
Come on Chevy Guys, how do ya do it, how do ya change ignition timing without the ECU throwing a P-code and turning on the "CHECK ENGINE" light?
The difference between the correct (Retarded) ECU timing and Hot rod timing is; NO burn out and a Good tire smoking Burn out. So, the power is there. Please, do tell ALL how to turn off the "CHECK ENGINE" light for this Ignition timing issue.IMG_4137[1].HEIC
Reference;
No ya can't move the distributor around anywhere ya want cause, the distributor hold down (crows foot) fits the Distributor shaft housing so tight there is not much room at all for clocking the Distributor.
No ya can't move the distributor around anywhere ya want, as I read in an earlier post the Crank shaft position sensor is ECU monitored against the relative position of the Camshaft sensor.
No ya can't move the distributor around anywhere ya want, as I read in an earlier post the Oil Pump tab fits together (like a screw driver to slotted screw) with the Oil Pump slot. So in order to change the timing you need to pull the distributor and turn the pump with a screw driver to a point where an educated guess matches the Pump shaft, Camshaft Gear, Distributor and timing set point. So a Guy really needs to know what he is doing here or  the Oil Pump shaft will be crammed down inside the pump and destroy it.
No ya can't move the distributor around anywhere ya want, as I read in an earlier post the ECM (ECU) constantly monitors where the timing is to be set, not the other way around where the Back Yard Mechanic tells where to set the ignition timing and when the Back Yard Mechanic does set the timing which violates these ECU parameters then the ECU Rats a Guy out, throws a code and turns on the "CHECK ENGINE" Light.
Once the check engine light is on then the ECU (PCM) parameters are wrong and other systems as in Transmission shifting get all messed up.
Edited by txab
You will need a tech2 or equivalent to set the timing, the distributor drives the oil pump in the same manner it has since the debut of the small block , nothing new there
    • I'm not sure if this should be a new topic, let me know if it's out of place. This my first post. Thanks 85077522 - AC Delco GM Genuine Parts Brake Master Cylinders. Anyone else had to replace this brake master cylinder yet. I didn't do any brake work, it looks like new parts and I've had the truck for about 4k miles, 119k total miles.  When it started to throw codes I did the calibrations with a bidirectional scanner and got the codes to clear but they came back so I did the routine; base bleed, automated bleed and final base bleed. All that with Bosch ES16-32N fluid (please look it up). That seemed to fix it but 100ish miles later it failed again so I ran the same process but with a pressure bleeder this time and got the same results, fixed for 100ish miles. The original fluid looked bad and I thought I got most of it out, it could've been the wrong fluid. The codes; P25A2, C05B0-00, C2A1B. I can get them to clear but not for long. The C05B0 indicates a leak in the front circuit (which is bone dry) so I'm thinking of doing the bleed process on that front again today and I don't know if that's taboo to just do the front but at this point it seems like it's worth the try anyway. The new master cylinder/module unit is supposed to get here today. But now I'm pretty much convinced this install is over my head. I've called several shops and some mobile guys that I know but this thing is like radio active material, scary wise. I did get 2 local shops say they should be able to do it, one says he has the SPS2 programing capability. And with the battery disconnected is there supposed to be pedal resistance, mine is to the floor, then if I pump it I can get some resistance. I had a panic stop prior to this issue which may have contributed from what I read. And on the first attempt to bleed and hydraulic test the scanner listed things to look for and one was any gaps between the pad and rotors which I did notice on the RF corner and I removed the outer pad (where the gap was) cleaned it and the hardware and didn't see a gap after that but will re-check it. I read that if pushing the caliper pistons back then you're supposed to open the bleeder so as to not push fluid backwards into the abs module or it will damage it. If that's true then that's also a possibility from the previous owner having the brakes changed before I got it. I'm using an XTool ip500 scanner. Any suggestions, questions and comments welcome.
    • Next Friday will be my 6 week point from my right knee replacement.  The surgeon says it will be fine if I choose to drive after this checkup.  I know I could drive now but best to do as my surgeon (and my wife) tell me.  Richard compared being 62 to 72.  I remember when I was in my early 60's I was experiencing slow but regular decline in my mobility.  Thanks to good medical support,  i continued to fight the speed and spread of this decline. During my 60's I worked on non-surgical methods and just when I turned 70, my orthopedic surgeon recommended joint replacements.  In a little over a year, I had one shoulder and both knees replaced.  This hasn't been a terribly fun experience, but worth the discomfort as my future mobility health trajectory has reversed.  It is a treat to now be watching my mobility. balance and confidence steadily improve!
    • Grommets with the right cement should be perfectly fine.
    • This is going to take allot of Assembly
