I was driving to work in my 2020 GMC Sierra Denali, and got this message on my display "service power steering drive with care". I parked at my site, finished my day.  When I was driving home, I lost the power steering on a mountain road for a few seconds. The Truck only has 37,000 miles .not sure if this truck is safe to drive. any other members have this problem?
Welcome to the forum. Check the ground strap in the engine compartment. Passengers side from the firewall to the frame. Corrosion there has caused lots of problems on these trucks. If that's not it get it looked at ASAP.
Thanks Bikerjon,
Do i have to remove the wheel well lining to find this wire?
