I already have the front coilovers & rear shocks. I can get the springs cheap locally.
Question for the real pros out there... are all of the parts in red carryover? Or do I need to also hunt down these ZR2-specific assembly bits?
36 minutes ago, silveradosid said:
you shouldn't reuse the U bolts the rest is ok
Just U-bolts?! perfect
any idea what I should search for? OEM? aftermarket?
What exactly are you working on here?  What "springs locally" are you looking at?
Being you posted in the 2019-2025 1/2 ton section, I can only assume you are working on a 1500?
If so, that spring kit you posted doesn't even fit a Silverado/Sierra.  That kit is the long travel kit for a 2018-2022 Colorado ZR2.
23 silverado 1500
1500 ZR2 springs
correct
If so, that spring kit you posted doesn't even fit a Silverado/Sierra.  That kit is the long travel kit for a 2018-2022 Colorado ZR2.  just a reference
1 hour ago, 23RST said:
The u-bolts are now considered re-usable per GM SI.
As for getting ZR2 springs, I don't think you will get any lift from those if you are looking for the ZR2's height, just different spring rate.  I say this as a Trail Boss to a ZR2 the shocks bolt right in no spring swap for the rear.
To get the height you need the rear blocks for Trail Boss/ZR2.  11603207 are the u-bolts, 84379975 are the spring spacers and 84625975 is the jounce stop plate.
All I want is the ZR-2 leafs, corresponding rear ride height & whatever secondary parts required to do so. Sounds like that's.... nothing? I just re-use everything currently on my RST?
No different brackets, bolts, lift blocks, etc?
Edited by 23RST
Uh.  No.
You need what I listed.  The longer bolts, the spring blocks, etc.  They gain the height with blocks from the factory.
The ZR2 springs don't add height as far as I can tell.
If you have the mono leaf out back you need everything.  Springs, blocks, rear shackles, u bolts, etc.
Edited by newdude
25 minutes ago, newdude said:
Uh.  No.
Got it, thanks!
So,
4x 11603207 u-bolts
2x 84379975 spring spacers
2x 84625975 jounce stop plate
Edited by 23RST
57 minutes ago, 23RST said:
Got it, thanks!
So,
4x 11603207 u-bolts
Yes.  I forgot the hardware for the plates.  11602292 x4 and 11602267 x8.
The u bolt nuts you can re-use.  Same with the spring mounting bolts/nuts.
Edited by newdude
you're the man! thank you
I REALLY wish you'd stop posting old school WRONG information.
The ZR2 leaf springs have a softer spring rate to match with the DSSV dampeners. You will lose some towing and payload capacity. Check the differences on GM's site of an RST vs ZR2 towing and load capacities. There is no lift with the ZR2 springs. I think the block is a 2.5" vs 2" on the Trail Boss.
ZR2 and Trail Boss use the same p/n block.
OK. It was my understanding it was slightly larger to gain the extra .5" lift in the rear.
    ChristopherDobson
    ChristopherDobson
  • Who's Online   4 Members, 0 Anonymous, 1,295 Guests (See full list)
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
