I already have the front coilovers & rear shocks. I can get the springs cheap locally.
Question for the real pros out there... are all of the parts in red carryover? Or do I need to also hunt down these ZR2-specific assembly bits?
36 minutes ago, silveradosid said:
you shouldn't reuse the U bolts the rest is ok
Just U-bolts?! perfect
any idea what I should search for? OEM? aftermarket?
What exactly are you working on here?  What "springs locally" are you looking at?
Being you posted in the 2019-2025 1/2 ton section, I can only assume you are working on a 1500?
If so, that spring kit you posted doesn't even fit a Silverado/Sierra.  That kit is the long travel kit for a 2018-2022 Colorado ZR2.
23 silverado 1500
1500 ZR2 springs
correct
If so, that spring kit you posted doesn't even fit a Silverado/Sierra.  That kit is the long travel kit for a 2018-2022 Colorado ZR2.  just a reference
1 hour ago, 23RST said:
The u-bolts are now considered re-usable per GM SI.
As for getting ZR2 springs, I don't think you will get any lift from those if you are looking for the ZR2's height, just different spring rate.  I say this as a Trail Boss to a ZR2 the shocks bolt right in no spring swap for the rear.
To get the height you need the rear blocks for Trail Boss/ZR2.  11603207 are the u-bolts, 84379975 are the spring spacers and 84625975 is the jounce stop plate.
All I want is the ZR-2 leafs, corresponding rear ride height & whatever secondary parts required to do so. Sounds like that's.... nothing? I just re-use everything currently on my RST?
No different brackets, bolts, lift blocks, etc?
Edited by 23RST
Uh.  No.
You need what I listed.  The longer bolts, the spring blocks, etc.  They gain the height with blocks from the factory.
The ZR2 springs don't add height as far as I can tell.
If you have the mono leaf out back you need everything.  Springs, blocks, rear shackles, u bolts, etc.
Edited by newdude
25 minutes ago, newdude said:
Uh.  No.
Got it, thanks!
So,
4x 11603207 u-bolts
2x 84379975 spring spacers
2x 84625975 jounce stop plate
Edited by 23RST
57 minutes ago, 23RST said:
Got it, thanks!
So,
4x 11603207 u-bolts
Yes.  I forgot the hardware for the plates.  11602292 x4 and 11602267 x8.
The u bolt nuts you can re-use.  Same with the spring mounting bolts/nuts.
Edited by newdude
you're the man! thank you
I REALLY wish you'd stop posting old school WRONG information.
The ZR2 leaf springs have a softer spring rate to match with the DSSV dampeners. You will lose some towing and payload capacity. Check the differences on GM's site of an RST vs ZR2 towing and load capacities. There is no lift with the ZR2 springs. I think the block is a 2.5" vs 2" on the Trail Boss.
ZR2 and Trail Boss use the same p/n block.
OK. It was my understanding it was slightly larger to gain the extra .5" lift in the rear.
    • The problem with failure rates or increase failures are there’s people who don’t have a problem. What are you doing wrong they say. We had 4 5.7 GM diesel’s in the family when they came out. One was flawless. My uncle who happened to be the most abusive. Early rotary engines were known to use oil. I abused my first car so bad in six months I replaced the clutch, transmission and rear end. It didn’t use oil. My brother in law has a 2013 Tahoe and an older Yukon. The Yukon has 280K miles. The Tahoe around 175K. He runs them to about 300K. If his lifters fail before that time he would consider it a failure. My Hondas, I know people hate it when I mention them. Identical engines. One with cylinder deactivation one doesn’t have it. One shudders when the eco light goes on or off. Cylinder deactivation. But wait! According to the web. It can happen with lock up too. So now people in the know are changing the oil and transmission fluid more often. Then you read it could be a programing issue. So what do you do? There’s lots of money involved. I see three ways to deal with it. One only works if you don’t drive lots of miles. Lease, never get out of warranty. Or only buy older vehicles with a good track record. They all have bad runs. Usually when there’s a change. Even Toyota and Honda.
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
