Nothing to wow everyone about but would like the option to make them go back up with the fob. You can put the windows down with the fob but can't put them back up. I have that auto window down option turned off anyway in the Infotainment settings, I  would turn it back on if you could raise the windows by the remote fob.
I've never understood this - with the exception of a VW Passat (2008), every vehicle I've owned can do down but not up.  Makes no sense because it's 100% pure software.
I would think the no windows all up feature via key fob is a safety thing. If someone has a body part in the window
and someone puts up windows without being in the truck, it could cause injury. Yes, GM has to always be thinking about the stupid people and lawsuits.
I had an after market device on my corvette that allowed windows down and up. It was made for convertibles so you  could put top up or down followed by windows.
I used it on my Z06 to get in and out easier with windows down.
My 07 and 15 mercedes have auto up/close windows with the keyfob, including the sunroof.
Sometimes it takes GM a while to wake up and catch up  - my 03 BMW rain sensing wipers yep, my 22 Sierra nope
I have the rain sensing wipers in my 24 SLT and they completely suck.
    • On 2021 3500hd it consistently sets automatically when selecting park if the incline/decline is above a certain angle.
    • Curious, did anyone ever get a fix for the vibration reported here.   I have a 2024 Silverado with 6.6 duramax.   I’m noting the same vibration resonating up through the steering shaft into the steering wheel.    Best way to describe- like someone is tapping on the steering shaft/components and it’s resonating into the steering wheel.    thanks.
