I also did this on the 2023. I use Testors model car paint. I'm sure Rustoleum would work, too. I would like to do something similar to the Duramax lettering. I think that should be vinyl. 20250518_072921.thumb.jpg.a433153890dca1fb9009174d0a747a16.jpg
Edited by Jus Cruisin
I swapped everything to the equivalent of "Dark Essentials".  I tried Plastidip but too many small corners and crevices and I couldn't get a good finish.  My purchases:
GM 86539780 - Black Emblem Kit (Includes (2) Silverado fender badges, (2) Duramax and (2) 6.2L badges, and the tailgate "Silverado" and "LTZ" badges.  - $75 on eBay
(2)"Texas Edition" Emblems in Black - $13 on eBay (my truck is Texas Edition)
GM 84434790 - Combo black bowtie package for grille and multipro tailgate for 19 -22 pre-refresh - $49 on eBay
GM 84432695 - Black Z71 Emblems - $36 on Amazon
If you are doing this yourself, also highly recommend a heat gun and an eraser wheel.  It makes removing and cleaning the areas around the old logos MUCH easier.
Very happy with the outcome:
Edited by parthery
Here's another that I'm working with tvd vinyl to produce. I've sent them tracings and measurements. I received a prototype to test yesterday. I think it's fine. I emailed them pictures this morning. They are floating on soapy water (temporary) 20250605_171432.thumb.jpg.efa24482b73cdf6b5dddaf9bac614ff5.jpg20250606_072630.thumb.jpg.06baca46da4af7430e7884c7a4d5fd2d.jpgin the pictures as they are orange and I will end up with red.
Anyone have any ideas on how to get this back to red? the "5.3" was red and now its so faded its almost silver.
See the first post if they are indented.
  • 3 weeks later...
On 5/24/2025 at 7:01 PM, Jus Cruisin said:
My second 10 minute mod. Installed the jumper cables to run amber drl's. Screenshot_20250524_185412_Ring.thumb.jpg.5cd59219129c1c3a561395c4e2d4ba0d.jpg
Did you use the Venom Trucks kit?
Yes. I had it on my 2023 GMC and swapped it to the 2025.
My next 10 minute mod is going to be the gen5diy kit to add a switch for the cargo lights in the bed.  One of the things I really miss from my F150.  $44 and it should be here by the weekend.
  • Thanks 1
  • 3 weeks later...
Bed light switch is in.  Kit was $46 from gen5diy.com and I picked up an $8 surface mount switch on Amazon.
Might have taken a bit longer than 10 minutes but not too much longer :)
  • Thanks 1
    • Breaking News!    I'm going to tell you that I'm going to tell you.  Then I'm going to tell you what I'm going to tell you.  Then I'm going to tell you.  Then I'm going to tell you what I told  you.  Then I'm going to tell you what I'm about to tell you on the other side of the break.  Then we're going to break. Then I'm not going to tell you what I told you I was going to tell you.  But I'll tell you something else that is Breaking News just coming to the desk that everyone reported on yesterday.  Then I'll tease a human interest telling I'll get to on the other side of a larger break. Then I'll tell you one item in 20 seconds and go back to an even longer break. Longest break of the night.  Then I'll tell you a fluff piece that takes 10 seconds and sign off into a three minute break while you wait for the next 30 minutes of rinse and repeat on the local news.    In al you'll get about 12 minutes of something, 5 minutes of which is worth hearing in a 30 minute show and 18 minutes of advertising at a sound level twice as loud as the news.    Of course you can switch to cable news and hear 12 different people tell the same four stories in much the same format as the Network News for 20 hours of which the majority will be advertising.  And four hours of late night Specials about things you wonder why you stayed up to listen to. Half of which will be repeats.....   OR you can go for a drive
    • Did you ever figure this out? My 2022 Trail Boss, and now my 2026 LT did this from time to time.  I believe it was more connected to Android Auto and my phone being the cause. Maybe try going for a drive, sans cell phone.... and see if it happens?
    • I have a 2026 Silverado LT, the non bose as well.  Upgrading the door speakers is pretty straightforward. You could honestly go to walmart, or Auto Zone/ O Reilly and get a set of 6x9s for the front, and 6.5s for the rear. You do also have to get some adapters for each, but they are like $10 a pair on Amazon. Then some plug and play harnesses that are about $10 a pair on Amazon as well.  And I would also suggest a 10 pack of the Amazon Basics sound deadening. Slap that all around the speakers and on the open metal of the inside of the door. And your golden.   I am currently doing this with my Silverado. Although I am having a bit of trouble because I am snooby I guess and bought some Alpine S2 S69c's which are 2 way components and I am having to wire from the door up to the dash....  Having never installed speakers before, its taking me just a bit to get everything correct. But if you dont buy expensive component speakers, and just some $40-$50 door speakers. You will DRASTICALLY improve the sound over these stock paper cone junk speakers. I thought my Silverado had an issue with the radio/ sound for a while.  Come to find out.  The stock speakers are just THAT SH*TTY   I cannot wait to have some decent sound in the truck   What did you end up doing?
    • Its all automatic based on yaw sensor data.  If enough incline is detected, it engages.   My recommendation though would be to disengage it before driving off and not let it auto disengage by touching the gas pedal.  The HD trucks use the same setup as prior years, the drum in hat park brake.  But now with an electric actuator.  If you drive off repeatedly over time, it can torque the park brake shoes and can also prematurely wear them out.           Electric console shift will set the park brake on flat ground too.  Pretty sure they've got it programmed to activate every time.
    • Anyone install a a supercharger on your 6.6L L8T? Talk to me...
