Hello All,I just bought a 2020 Chevrolet Silverado LT.It only came with 1 key and 1 3 button key fob.It has a keyed ignition. I am trying to find the instructions to program a new transponder key,as well as the instructions to program a new key fob.
On my 17 silverado they cut a new key, with the old key I started the truck, turned the truck off and there was a short window to put the new key in and the truck learned it.
I would ask a locksmith before going to the stealership.
Edited by Hoginedgewood
Method required depends on generation of truck.
In some cases it depends if it was built for Can or US.
2020 Owners manual has this information.
2 hours ago, 20CHEVYRIDER said:
So I should follow the steps that says programming without recognized keys? Even tho I have 1 recognized key right?
Yes, if it was originally sold in the US.
I reads like if you have a truck originally sold in Canada, you need to see the dealer...
Edited by redwngr
Ok so I got the key cut today.I had a question about the instructions? Do I start with my original key or the new cut key I made today?
I was able to program the new cut key today.I started with the new cut key then programed the original key.
On 6/1/2025 at 2:03 PM, 20CHEVYRIDER said:
Ok great thanks for your help will try to get the key cut this week and try the instructions. What about programming the new fob?
Your dealership is in the best position to assist with programming another key for you, and they would be happy to help! If you'd like us to set up an appointment for you, email us at [email protected] and we can help. By sending us a message, you consent to the information you provide being monitored and recorded by GM or those acting on GM’s behalf, subject to the GM Privacy Statement: https://www.gm.com/privacy-statement.
    • They’re not the same wiz as 10-15 years ago.  QC has fallen pretty hard.  The XP line was never good though in the first place.    https://bobistheoilguy.com/forums/threads/wix-filter-rusted-through.386492/post-6991372   https://bobistheoilguy.com/forums/threads/i-ve-used-my-last-wix-filter.27299/   https://bobistheoilguy.com/forums/threads/looking-for-a-better-replacement-for-wix-51258.403977/   https://bobistheoilguy.com/forums/threads/convince-me-in-using-the-purolator-boss.401537/post-7420147   the forums are littered with posts and examples of not great wix filters the last couple years
