I own a 2006 sierra denali with the 6.0 gas. A few days ago I drove through a pretty deep puddle (I know the danger now) and immediately after my engine started knocking. It never stalled, never died or stumbled while in the water. I pulled my intake and it was full of water, filter was soaked. I let it dry while I worked, and let the filter sit in the sun for a bit. Put it all back together and on startup and at idle it did not knock. I could even raise the rpm's and it wouldn't. However once I got about 60 seconds into my drive it started again. Same thing today, it didn't do it on startup or revving at idle but once I put it in drive and went it came right back. I know the obvious answer everyone's gonna say is I bent a rod when I hydrolocked a cylinder, but wouldn't that make noise consistently? And raise with rpm's? Looking for if anyone knows any other possible reason as to why it's knocking or what I'm missing here
Try it without the air filter and see if that helps. The water may have damaged it
16 hours ago, richard wysong said:
How's the oil look?
Oil is clean. Changed it a little bit before the incident and it's still clear clean looking oil, not milky.
With the airbox soaked with water the water may have damaged the MAF sensor and screwing up the air/fuel mixture.  You don't have any codes? I would try and disconnect the battery for about 15min or longer to reset the computer as this could have screwed up the readings for the computer. Yeah definitely not hydrolocked.
Edited by Silverado4x4
Good thought!
Is all the water out of the intake? Some are almost impossible to get all the water out. It will sit in there till revved. Then, boom.
I do have codes like p300 and lean fuel on bank 1 but I had that before. No new codes. I pulled the tube off from the box to the throttle, should I pull the throttle and intake manifold too? Maybe waters stuck in the manifold and causing noise?
Without the filter it makes the same noise
Up until the throttle yes, I didn't go further than that. Would it get past the throttle and stay there?
On many modern engines, once a liquid gets in the intake, it`s a good idea to change it. You can`t just pour it out. It will stay in the bottom of the long runners. Then, with enough air velocity, it will make it to the cylinder. Then, a bent or thrown rod. Maybe not your particular intake but, something to think about. I would at least pull it and see if water is in it, and if you can get it all out.
So I finally got around to pulling the manifold. There was a decent bit of water in there mixed with oil. Got it all out and dried it, reinstalled and the noise is still there.
Anyone have any ideas what could be rattling around? I've checked it over and over and I don't see anything. Maybe it warped something like my exhaust? Did hit the puddle right after coming off the highway so it was definitely hot
If it`s not the engine, then maybe the cat core is broken and rattling around. The cat is usually very hot and driving through cold water shocks the ****** out of it.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 258 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
