Silly question, but my mechanic made this joke, what's the point of a 3/4 ton when you can option a 1 ton into basically exactly the same truck? Why still make 2500s? Just curious
When we were looking for a truck to replace the crappy Tundra, we looked at 3/4 tons and the selection was very limited. The ones we saw were more like work trucks with cloth and minimal accessories.  We looked at Ram and GM mainly because of the big diesel offerings. The Ram dealership was too shady to deal with (bait and switch).
The 1 ton came with more options and was full of features that we couldn't find elsewhere.
Marginally better ride on the 2500s due to the 2nd stage being farther away from the main leaf pack vs the 3500s. But otherwise a legitimate question, there used to be a lot more differences between 1500/2500/3500 style trucks but since now the 2500s/3500s share the same frame and most everything else they’re pretty much the same truck.
Certain states still have weird parking laws and commercial registration costs for things with a GVWR higher than 10,000lb.
In the Ram world, the 2500 is on coils in the rear and the 3500 is on leafs, so there is ride quality implications.
I bought an 2500 AT4HD gasser even though I didn't need one. I didn't like some of the features on the new GMC 1500's and definitely didn't need a 3500 SRW. The 2500HD was a good choice for me. If the choice was a 1500 or a 3500, I would have got the 1500 and would have hated some of the features.
In case you are wondering, I don't like the electronic console shifter, start/stop and cylinder deactivation. I never drove a 1500 with the console shifter but always like a column shifter. My last 1500 had a column shifter and cylinder deactivation, but did not have start/stop. My AT4HD is my first truck with push button start. I think some of the 1500 lower trims still had a column shift. Either way, free country and I can spend my money as I see fit! 😀
The lack of a column shifter in the 1500 put me over the fence to the 2500.
Also, I don't like the squarish tile pipes.
They both have their place, I think.
3/4 ton is perfect for showing off and daily driving.
1 ton’s for when there’s real work to do.
I used 3/4 and one tons for work. I didn’t feel any difference between the two with my equipment in back or for the short periods empty. I switched to one tons for the dual wheels. When I quit hauling my own equipment I couldn’t get into a half ton quick enough. Now approaching 70 Im tickled to be in a small truck. I recently drove my brothers fully loaded Ford diesel one ton single wheel lariat. Loaded with a 100 gallon tank, tool box and an air compressor generator. Very nice truck. I guess you get used to them. No way I’d drive them if I didn’t need to work them.
I feel like your the only answer here that is actually answering the question. Everyone else is lost, lol.
GVWR, GVWR and GVWR.  You can order a 2500HD de-rated to 10,000 GVWR for DOT purposes.  Can't order a de-rated 3500HD.
2020-current HD does have some frame differences in the rear half.  Extra crossmember or two that the 2500 does not get UNLESS you order a 2500HD with the NHT max trailer which gets you the 3500HD frame and 12" axle.
Ah for some reason I thought they were the same frames other than the perches for the extra springs.  Makes sense being different though, I'm assuming the dually frame has even more differences.
Some of the items you list off are also reasons why I debated between a half ton and an HD, I did not want stop/start ( yes with some gimmick it could be turned off ) and I certainly was not wanting the the cylinder deactivation due to its potential of failing and they certainly can fail. I also wanted a reasonably low ( numerically higher ) diff gearing and the two speed transfer case and GM has cluster fd up that so bad with most models not being able to have a two speed transfer case AND the max tow package with the lower diff ratio. The half tons are rather sad at carrying a load which of course also means they ride better because of it, can't have it both ways unfortunately. Console shifter I would not have minded but the electronics is just one more potential problem I saw it as. Also the half tons theme unless its a trail boss etc is low to the ground and I like being able to fit under the truck to service it without having to jack it up for every little thing. My insurance rate is actually somewhat lower on a one ton than either a half or 3/4. Will I use the one ton in the future for what it was designed, perhaps as in towing a trailer, maybe even some farm equipment, and possibly a slide in camper although the short box is a limitation there ( by rights a long box dually for the campers I prefer is the correct truck for that theme ). I like sitting up decently in traffic and the newer HD trucks certainly check that box vs feeling like driving a car.
The downside is my truck is a bit longer than its half ton twin but I have slightly more box length. The ride certainly isn't there but with my running low pressures I am finding it an acceptable compromise. The fuel mileage, well that certainly isn't of any benefit with the gas engine HD anyway. Never the less so far I am not regretting my decision to have gone with an HD truck and it opens up options of things the truck is capable of that a half ton just was never made for and yet I see some trying to do with a half ton because that is what they own.
4 minutes ago, Chuck FB said:
Some of the items you list off are also reasons why I debated between a half ton and an HD, I did not want stop/start ( yes with some gimmick it could be turned off ) and I certainly was not wanting the the cylinder deactivation due to its potential of failing and they certainly can fail. I also wanted a reasonably low ( numerically higher ) diff gearing and the two speed transfer case and GM has cluster fd up that so bad with most models not being able to have a two speed transfer case AND the max tow package with the lower diff ratio. The half tons are rather sad at carrying a load which of course also means they ride better because of it, can't have it both ways unfortunately. Console shifter I would not have minded but the electronics is just one more potential problem I saw it as.  Will I use the one ton in the future for what it was designed, perhaps as in towing a trailer, maybe even some farm equipment, and possibly a slide in camper although the short box is a limitation there
What's funny is, you could have had all of that in a 1500 High Country.  1500 HC comes with the 2 speed transfer case no matter what.  You can option in NHT Max Trailer, and as far as engine goes, 5.3 and 6.2 and if you paired it with the Range DFM Module would have disabled DFM, and the 3.0 Duramax would have no cylinder decativation at all.  Stop/start?  There's a button on the dash for that.
Don't take any of my comments as negative in regards to your comment, its only my experiences as well as other engine failures of those I know personally that steered me in the direction I chose for my current truck.
You may be right as far as the two speed, however the GM website does not show the two can be mated up with anything other than the 6.2 if both max tow and two speed are desired. Also when I talked to the salesman who has been in the business for years and is the commercial sales manager, he was saying the same thing but he may have been wrong as well. The button on the dash, yes that one that always has to be remembered every time one starts the engine at every store and business, I have heard my brother curse his Jeep Rubicon so many times because of that stop/start and I knew I would have had to find a way to defeat it. But speaking of the DFM, I have heard of them piling up even with a module being used, I really didn't want that potential issue being in the engine at all and yes that left me with the 3.0 choice and I certainly thought about it but with our winters the emissions issues of diesels really rear their head then as far as DEF for sure and a diesel engine period for starting when forced to without the ability to plug in a block heater, -40 weather and colder ( and does not have to even be that cold ) and its a real struggle with diesels. I would have bought a 6.6 Duramax as that was actually my first choice in a truck but again the cold weather we struggle with and the emissions issues that are very real, I just felt it would make life easier to go gas and not deal with gelled fuel issues, and emissions failures. I've had past experiences with older technology diesel vehicles ( and plenty of equipment ) and granted they never were made to start as well as the newer ones but I did not like how the block heater was literally my umbilical cord life line to using the vehicle and add in two diesel vehicle engine failures or one on its way out and the other a true engine failure and both vehicles in question were basically sold at give away prices, that is hard to erase out of ones mind.
There is one other factor around here that gets the check mark for a larger/taller truck and that is the very real fact of life of hitting wild life, not that driving an HD truck means survival either but being bigger helps
6.2 and 3.0 Duramax in a High Country come with the 2 speed case no matter what, and can both be combined with NHT max trailer.  This is achievable right in the build and price on chevy.com.
Was just looking to add some facts/details to this for others reading who may be thinking of NHT vs HD if they'd rather steer towards the NHT setup and don't need the HD capability.
As for the "vehicle surviving wildlife", once you've spent time at a body shop you realize it doesn't really matter.  They are all designed to crumple.
Edited by newdude
    daveishi
    daveishi
  • Who's Online   5 Members, 0 Anonymous, 442 Guests (See full list)
