Like most here I've lifted my rig (3 1/2  inches) and the computer cant configure the parking assistance lines so 99% of the time so im just getting the hour glass. There needs to be some type of work around for this available? Trucks get lifted and also get LARGE aggressive tires put on them. The dealers been no help other than the slow 15 minute drive around the parking lot to get the lines back on which is great until the computer goes to sleep and the process starts all over again. Anything would help.........it honestly makes parking at night much easier.
What about someone buying an OBD pass through/GM MDI and buying the 3 day subscription to AC Delco TDS?
Spendy? Yes. But could be an option? Dunno.
1 hour ago, Ryan Tierney said:
OBD pass through is what I was hoping. I mean dealers are able to sell the lifted trucks and black widows with out issues so it should be able to get done.
Have you tried contacting a company like Black Widow Trucks or Rocky Ridge to see what they do?
GM will be of no help here so I'd stop wasting time with the dealer.  They can only offer calibrations for factory equipment.  For example if you purchase the 2 inch Trail Boss/AT4 lift kit, it has an authorization code that lets GM write cal files for the electronic power steering module and the forward collision camera for lane departure and forward collision.  There is nothing done though for the backup camera, that stays the same for that lift.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
