I want to change the filter, can it be done without pulling the intake?
Tips / Tricks / Links appreciated
I didn't find much when I used the "Google "
Edited by bayouguy71
grammar
I didn't much much when I used the Google
Not really.  Its under the molded foam insulator under the intake, so the intake has to be pulled to pull that foam.
Is it "possible" that you can try and move the foam enough?  Maybe.  But unlikely.
There's a screen under the oil pressure sensor that sometimes causes problems.  That probably can be replaced w/o pulling the intake, but it won't be easy.
Edit: At least it was there on earlier 5.3's, no idea about the later ones w DI.
Edited by davester
They do.  Its at the front of the valley now not the back like the LS, and it has its own access point that is not under the oil pressure sensor.  Its all under the molded fuel noise isolator/insulator pad which is under the intake though.
This is not the news I was hoping for, seems like a ton of work for something that would be considered normal maintenance?
I will take a look but I was pretty sure I could see the allen head for the plug but there certainly isn't much room above it.
Any progress with this? I’m nearly at 100k miles and wondering if this should be done. For those who have pulled the filter, was it clean?
That is going to depend heavily on your oil maintenance and vehicle service type. Varnish is the issue. Only you know your exact particulars.
It is not technically a maintenance item.
    250.6k
    President Roberto
    President Roberto
  • Who's Online   1 Member, 0 Anonymous, 209 Guests (See full list)
    • I don't wanna do major surgery/upgrades, behind-the-dash work, add amps, change radio etc. on my '26 std cab WT. On the WT, it has the base 7" IOR infotainment setup, and only two speakers (doors). Since I listen to classical, looked around for speakers that do well and dug thru reviews. Two-way speakers were found to be better than 3-way. So I've ordered a pair of  Infinity Reference REF-9632IX 2 way speakers.  [These may  or may not have been discontinued / succeeded by the 3-way ...9633 ones.]    These speakers are lauded for 3 ohm and 94db sensitivity spec so they'll work well for ordinary base car radios without amps and offer better performance (quality,  strength) than  default base paper-cone speakers. They'll be installed in a few days and I'll let y'all know what I think. Bill W San Jose
    • Thanks!   Changed out the rear shocks today to Bilstein 5100s.  So far feel much better. The stock Rancho were wore out.  Lots of heavy hauling (2 moves, home renovations, etc).  Next up is new BFG tires Monday.  Cant wait the current tires have little to no wet traction and are super loud (hum)
    • Ok, I got the all the codes. What do you all think would be a place to start?
    • How about I just point to the factory pans stand pipe little drain plug and claim its a pan with a real drain plug !. I just couldn't swallow the fact that a Dorman pan which at this point is probably the only pan out there that fits the gas version truck cost that much up here in Canada so I decided initially anyway to skip it and see what I thought of pulling the pan method and down the road if I felt inclined enough then I would either install a drain plug kit in the factory pan if there is enough room for it, or have a bung welded onto it, or put an aftermarket pan on. The thing is if the pan is not pulled then the magnets in the pan can't be inspected and cleaned or if wanting to change out the filter. However of course it certainly would make the job easier to be able to drop the oil first before having to handle the pan if dropping the pan that go around was the goal.    I knew a guy locally that was doing custom field spraying years ago with a pickup pulling a ground driven sprayer, I believe it was a GM pickup with an automatic trans. He had a drain plug in his pan and would drop the oil out of it once a week and top it back up through the dipstick tube to keep refreshing a portion of the oil often and that made the transmission last far longer than had he done nothing. Soft fields pulling 500 gallons of water at the start of each mixed up sprayer tank batch and in low range sucking along. I imagine he got some tips from other custom sprayer outfits doing the same thing at the time and learning from their blown up tranny mistakes. Transmissions then had no lock up converter so would cook the crap out of the fluid slipping that much and it would not have been synthetic fluid either.
    • 3.39 Kroger’s in Montgomery Texas.
