I am going to attempt some rust repair on my 2014 Silverado, welding with a mig welder. I wanted know if I need to disconnect the negative battery cable before welding. I am going to use a repair panel above the right rear wheel. I have never tried this before, and advice would be appreciated.
Thanks
Yes, you must disconnect the power. Honestly just take the both cables off the battery to be 100% sure.
Sheet metal welding is an art. You can't really weld beads, you are going to have to tac weld it a million times. You also can not do one section for very long because the thin metal will warp. Do a couple welds, then go completely across to the other side. Keep jumping around to not heat one section too much.
Watching youtube video's is helpful too.
Yes, learn how to do it on scrap sheet metal of the same thickness, until you can do it well w/o blowing holes in it all the time, then start on your truck.
And put the ground clamp as near as possible to where you are welding, grinding a clean spot for it to clamp to.
    • when it's greyed out that is it's way of telling you that it's downloading the patch in the background. Eventually it will be fully downloaded and then it will prompt you at ignition shut down to run the update. I highly recommend doing the update once you get home and can run it a few times. I've had several issues with updates not going the first time around and I had to retry the update multiple times in my driveway before it was successful.   Some updates are huge and take awhile to download. You can help it by connecting to your home WiFi and keep the truck on service mode for the ignition and keep it alive for awhile on a battery charger too. There are specs it needs to be in for updating such as a full enough battery charge, no running ignition, etc.
    • I am not techy at all but wondered if you have the truck running but sitting still in park as some functions gray out as soon as the truck is moving. I believe in the settings for updates you can choose for it NOT to update and I wonder by chance if maybe that was chosen before and now it won't allow you to chose to press update, I think that is back in the settings menu where it has all the items one wants on or off etc. Also I assume you have a wifi connection and checked that it has some signal strength, not that it would have anything to do with the grayed out updates choice in that case. What I am thinking out loud of here may be be of no value but thought I would suggest it, sometimes it can be the simplest thing that resolves an issue.
