I wasn't able to find this information anywhere, so I thought I would go ahead and post it in case any one else needs it.
If you have the Sierra Multipro or Silverado Multi-Flex (Multifunction) tailgate (RPO Code QT5) and don't have power to the truck, there is no way to open the tailgate.
It's actually pretty easy to open it. You just need to disconnect the connector for the tailgate under the bed, and you can manually power the latches. I attached the connector end view diagram to this post. On the diagram, its the left connecter at the top of the first page.
If you want to open the main tailgate, apply 12V to Pin 30 (Green) and Ground to Pin 17 (Yellow with Black Stripe) and it will open the latches.
If you want to open the inner/upper tailgate, apply 12V to 16 (Violet) and Ground to Pin 18 (Brown with Black Stripe) and it will open the inner tailgate.
I use a portable jump box as the power source and paperclips in the connect pins. I use a set of test leads with alligator clips from the paper clips to the jump box leads.
Hopefully this helps someone else.
Edited by teesee150
No power, just jump it and hit open to get tail gate open. Wouldn’t that be much easier then the steps above?
I work on a lot of salvage/wrecked vehicles so this is not an option most of the time. Or if you are having a problem with one of the modules/switches in the truck and the tailgate won't open, this is how you can bypass all of that.
I've had several trucks where the inner tailgate won't open because one of the sensors in the latches has gone bad so the truck refuses to open the inner tailgate. Typically you would need to take the tailgate apart and manually release the latches, this bypasses all of that as well.
Edited by teesee150
    • I included the first gen-cylinder de-activation (active fuel management) in my statement.
    • Hello All!   My 2019 Colorado 3.6 LT, 4WD Crew Cab has approximately 77,500 miles and I recently began experiencing the well-known transmission shudder between about 30 and 65 mph. The problem had worsened to the point that I could no longer attribute it to road conditions - and I had decided to bring the truck to the dealer - when recently, I experienced a sudden loss of power while driving at maybe 40 MPH. Several warning lights flashed, the “Check Stabilitrack” message appeared, and the Check Engine, Stabilitrack, and Traction Control icons remained illuminated. The truck regained driving power, but it stayed in a low gear with unusually high RPMs for the speed. (limp mode?) Because I was only about two miles from home, driving slowly, I was able to make it back and run an OBD-II scan, which showed fault codes U0101, P0700, and U0100. My next trip in the truck was to drive it to the dealer the following day. That trip began normally, but after about a mile I experienced another loss of power, along with the same warning lights and the same “Check Stabilitrack” message. As before the truck remained driveable, but again operated at an abnormally high RPM-to-speed ratio and seemed stuck in a single gear. About a mile later, the dashboard lit up once more, this time displaying “Check 4WD.” Soon after that, I arrived at the dealer. I have verified that the truck still has its original factory transmission fluid, which means it has never received the corrective fluid exchange outlined in GM Technical Service Bulletin #18-NA-355.  That was Thursday of last week and I've heard nothing yet from the dealer.    According to Technical Service Bulletin #18-NA-355 and the build date of my truck, my truck should have the newer LV fluid. I've done a little research and read something about a problem with the wiring harness as well.   Anyone have an insights into this situation?  Thank you!!
    • Having bumper and other body damages can be very frustrating, especially as a result of a parking lot collision/bump. Our team wants to learn more about the damages to your truck so we can look into ways we might be able to help. When you get the chance, please fill out our support form with more details: https://s.gmc.com/support-request . A member of our team will follow up with you as soon as next available. We want to get you enjoying your truck to the fullest again.
    • Did you even read this article?   Even the title of the article says "U.S.-Iran Deal Doesn’t Mean a Swift Return of Oil and Gas Flows"   Remember, crude oil prices are based on FUTURE purchases by the oil companies.  Gas prices are based on FUTURE purchases by the station.  This article stated that many of the oil producing nations have to restart their processes to get the oil produced.  Then the oil has to be shipped to wherever.  And it doesn't get there overnight.  And most of that oil is not coming here. Check out this site:  https://afdc.energy.gov/data/10621   A graph will pop up to show where the US imports their oil from.  Notice that there isn't a lot of import from OPEC and Iraq.  Most of the US import comes from Canada. The US oil produces are selling their oil on the open market, which is why the US fuel costs went up.  So you're correct, the US oil companies are going to slow walk the price downward.
    • Having codes and an engine light with no hints on what might be causing it is nothing short of frustrating. How long have these concerns been present? We want to know more so we can look into ways we might be able to help you. When you get the chance, please fill out our support form with additional details on your experience so far. A member of our team will follow up with you as soon as next available: https://s.gmc.com/support-request
