I screwed up today and clipped a parked truck with my outside mirror.  Didn't do anything to the parked car but it flipped my mirror back very hard and broke the mirror.  The outside of the mirror is damaged as well.  I'm trying to figure out whether I should get it fixed out of pocket or go through my insurance.  Clearly, it's my fault and my deductible is $1,000.  Any idea what it would cost to have the entire mirror assembly replaced?  I did some googling and it looks like the part is about $700.  If I can get out for around $1500, I probably won't claim it.  What do you think?  Under or over $1500?
29 minutes ago, CamGTP said:
I don't know how loaded your truck is and the options package, so that makes it hard to know what mirror you need.
I see the power mirror, with camera and blindspot is roughly $413 without the cover. Then you'd need to buy the cover separate.
https://www.gmpartsdirect.com/v-2021-gmc-sierra-1500--denali--6-2l-v8-gas/body--outside-mirrors
Thanks.  I will need the cover.  Looks like I’m looking at around $500 for the complete assembly.  Hopefully I can get out of this for under a grand.
Looks like I’ll get out of this for under $500.  I found a collision shop nearby and they didn’t mind me supplying the parts as long as they got a copy of the receipt.  So I visited GM Parts Direct and ordered the parts.  The interesting thing is that, while it lists for $413, GM Parts Direct shows you all the dealers in your area and I found that some discount the part.  Luckily, a dealer about a half hour away had the part for $305 and the cover for $73.  I top of that, they had an extra 20% off AND I got to use some reward points I had from buying my last car through GM and that saved me another $67.  So I saved about $280 by handling the parts myself.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
