I’ve had both the weathertech’s and the husky’s. I like the husky’s better. I currently just have the larger gm splash guards. Not as good as a full mud flap, but do pretty well.
Husky’s front and rear. Went on easy and fit well.  Make a big difference in how much snow and crap gets tossed up the side of the truck and up under the rear bumper and all that.
I had considered a Weather Tec or Husky or for that matter a similar looking plastic type formed mudflap that the Chevy dealer was selling through their aftermarket parts here in Canada but in the end I decided to to for more coverage and got what is referred to as kickback mudflaps and these ones are made in Alberta ( this company is called Bulletproof ) but there are various brands out there of off shore or USA made ones. They are more expensive and they are a combo stainless steel upper ( black powder coated available ) and heavy lower rubber flap and they hang down further which was what I was after for even better winter road and rock protection for the truck and if pulling a trailer.
I just figured out that the dealer was in fact selling the Weather Tec flaps but they didn't name them as such but the part number is the same so they were just flogging them through their dealer aftermarket accessory system. If a person is not looking to get that much coverage, certainly the Whether Tec has a sleek formed look and not saying the Husky don't but they are a little different. However I believe one has to have the standard so called mudguards from the factory and not the optional longer hanging down plastic extended units as those I don't believe are compatible with some of these molded flaps, nor would those factory optional flaps have worked with these kick back flaps as they required the standard factory units to be compatible.
Edited by Chuck FB
Scroll through the thread below.  I put both Huskies and the WT on my truck and ended up with the latter.  Both are much better than the GM accessories ones that I had on my previous three trucks.
  • 1 month later...
I put RokBlokz mud flaps on my 2024. I had them on a previous truck and liked them. They bolt up using factory fender liner locations. I omitted their "mud flap delete" part that was included in the kit, because its was crappy 3Dprinted plastic that broke immediately while installing. But the flaps themselves are sturdy and will last for a long while. I just kept my OEM mud flaps in place and drilled some holes and used some spare hardware to secure the RokBlokz flaps to them.
Check out my install video below.
    • I will be one of those "blinded". One, I like new shiny things. Two, I've never kept any of them beyond the 3/36. Three, I don't finance anything. Four, yep, it's a waste of money....so,what? I'm doing my part of keeping automotive industry going and keeping my neighbors, most of whom are in it, employed. 😉      By the way this is the "signature... ¬
    • Although there is a "recommended" weight by those who sell trailers, my experience has been that they are way too aggressive in their information, for me at least. My '22 with 6.6 Gas, has a payload of about 3400 lbs and depending on your specs (I don't have 4WD so it has a bit higher Payload than others) yours will likely be different. Payload is one of the most important numbers for towing. Although you "could" tow the max trailer weight for your truck, I, personally, would not go close to that number. Having said that, a lot depends on how/where you will be towing. I live in the LMD of BC and often tow to Denver, Co, along interstates (flat and mountains) and I find I need to keep it in 5th (6spd) for the trip and travel at around 65mph. This is for a trailer dry weight of just under 3500lbs. If you are only doing local, short trips, it would not be that big an issue if you had a heavier unit. You will be surprised how much stuff you load the trailer with, so I would only recognize the trailers "full" GVWR weight rating, then decide on the appropriate trailer from that number. If you are worrying about how much stuff you should be putting in a trailer, you might have too large a rig from the get-go. Once again, depending on what terrain/distance in which you will be pulling. Marv
    • davester, Thanks for the response, how ever, I think I am now a bit more confused than I was before I posted - - After I posted, I actually found a YT video of a guy who replaced his Module (above tire) and he only disconnected the ground cable of the battery, but you describe rubbing the two cables together after disconnecting. I presume that is to do as you describe and eliminate any residual energy? - When I picked up the Module (between my posting and reading your response) from the dealer, I specifically asked about any re-programming and he stated it was not necessary as it was simply plug and play. Don't know how knowledgeable he is, though. - The video I watched also showed the Module plug to be difficult to "unlock" and remove, but there was no mention of silicone, although the video did show a bunch of dust/dirt in and around the plug (old truck) during removal. Are you talking about silicone that was applied by the factory, or silicone that you applied prior to plugging in? Thanks again, Marv
    • Looking for a clean, factory-style lighting upgrade for your 2022+ GMC Hummer EV? M&R Automotive's 40" Bumper Light Bar PRO features a vehicle-specific, bolt-on design with no drilling or cutting required. Choose a bright white or yellow main beam, both paired with an amber DRL backlight for a sleek OEM-inspired look. The kit includes a curved LED light bar, powder-coated brackets, and all necessary mounting hardware.    Learn more or order yours See how it installs and looks on the vehicle:
    • Looking for a clean way to add serious lighting to your 2019+ GMC Sierra 1500? Our M&R Automotive 40" SLIM Light Bar Kit was engineered to deliver maximum performance while maintaining a factory-inspired appearance.   Features: • Designed specifically for 2019+ GMC Sierra 1500 models • High-output 40" SLIM LED light bar • Clean, integrated grille-mounted design • No cutting or drilling required • Bolt-on installation using vehicle-specific brackets • OEM-style fit and finish   Whether you're hitting the trails, exploring backroads, or need additional visibility off-road, this kit provides powerful illumination without compromising the look of your truck.   For product videos, light output demonstrations, and installation content, check out our YouTube channel:   https://www.youtube.com/channel/UC3lutWP54fkXBl3iFLDJR-A Have questions about fitment or installation? We'd be happy to help.
