Whats up everyone, new here. I have a
2024 silverado turbomax. Bought a few new accessories for the truck one of them being a set of Led Bulbs for the headlights. I noticed there is no high beam bulbs. Also, I'm trying to remove the bulb and cant seem to budge. All the videos ive looked for and nothing comes up to this exact set up. Videos i find are for the heavy duty trucks or a couple years older. I have access from the hood and once u pull back the red tab. I try to turn it clockwise and counter clockwise and nothing. Also it doesnt have any rubber seals to pull back. Any suggestions?
did you look in the owners manual?  that typically describes how to replace the external lights, if they are replaceable.
It doesn't say. It points out to a model that has halogen bulbs. For anymore questions "contact dealer"  it says. i also saw somewhere that some models have a sealed led headlight. But I can't seem to conform this. Im able to remove the connector but the socket won't turn. Unless it not supposed to.
Headlight type is mostly driven by trim level, you didn't mention yours. But from your description and from what I've read in the 2023 OM, it sounds like you have LED's. In the 2023 manual, in the Vehicle Care section, page 358, it does talk about bulb replacement for the base trim level. For Mid and Up level trims it says only "...see your dealer".
Regardless, there's a specific warning in the manual that states "Do not replace incandescent bulbs with aftermarket LED replacement bulbs. This can cause damage to the vehicle electrical system." So even if you did have incandescent bulbs you'd not want to install LED's - at least not while still under warranty.
Sorry. I have a 2024. (Refreshed front) turbomax LT. Doesn't have halogen lights. I can see from the outside that the high beam has a couple LED diodes inside the light.
Time to return those bulbs then and get your $$ back.
    • Paid $2.72 for E85 today.
    • That makes sense, and I think you are describing the real product problem. Capturing data is the easy part. If the owner or technician has to manually dig through five minutes of millisecond-level logs, the product has already failed. The device would be at the ECM harness, not at the OBD port, so I agree that data retrieval and event marking need to be thought through carefully. The way I am thinking about the architecture is: The recorder itself should not depend on a phone, app, Bluetooth, Wi-Fi, or cloud connection to capture the event. It should always keep a local rolling buffer and lock the event locally. A button, phone app, or small cabin device would only act as an event marker. If the driver feels a stumble and presses the button 10–30 seconds later, the pre-buffer has to already contain the useful data. For data retrieval, the practical options would be a sealed service USB lead, Wi-Fi download, or a phone/cabin companion device. I would not expect the owner to remove the ECM-side module or work with raw files directly. The cloud or AI side would be for interpretation, not for capturing the event. The truck may have no connection when the issue happens, so the evidence has to be saved locally first. After that, cloud processing could help decode the data, compare it against baselines, and generate a readable report. For the first version, I would keep the automatic triggers conservative and objective: driver event marker bus-off error passive voltage drop / brownout device reset FIFO or queue overflow a normally periodic message disappearing side-to-side communication mismatch, if the topology supports that For “learning normal,” I agree with your point, but I would not want to overclaim it as automatic root-cause diagnosis at first. A realistic first step would be learned baseline comparison for that specific vehicle and operating condition. For example, a value would only be compared against similar conditions: RPM range load / MAP throttle position gear / vehicle speed coolant and oil temperature battery voltage AFM/DFM state, if decoded and validated Then the report could flag things like: this periodic message disappeared compared with its normal timing this value deviated from this vehicle’s normal range under similar conditions the same abnormal pattern repeated after the same type of event the anomaly occurred together with voltage, oil-pressure, misfire, or communication changes But I would still call that “abnormal pattern detected,” not “replace this part,” unless there is enough validated repair data behind it. So the intended product would not be “here is a huge log.” It would need to be an event package: what triggered the capture how much pre/post data was preserved what changed before and after the event whether the device itself reset, overflowed, or saw a bus error selected graphs around the event raw data only as supporting evidence From your perspective, what would make this kind of report useful instead of just another datalog? For example: What are the top 5 parameters or events you would want highlighted first? Would you trust a learned baseline for that specific vehicle, or would you prefer fixed thresholds? How much false-positive flagging would be acceptable before you stopped looking at the reports? What would a one-page report need to show for an independent shop to take it seriously? For misfire, AFM/DFM, oil pressure, or U-code complaints, what would you want the tool to flag automatically?
