big_chev Posted February 11 Posted February 11 Whats up everyone, new here. I have a 2024 silverado turbomax. Bought a few new accessories for the truck one of them being a set of Led Bulbs for the headlights. I noticed there is no high beam bulbs. Also, I'm trying to remove the bulb and cant seem to budge. All the videos ive looked for and nothing comes up to this exact set up. Videos i find are for the heavy duty trucks or a couple years older. I have access from the hood and once u pull back the red tab. I try to turn it clockwise and counter clockwise and nothing. Also it doesnt have any rubber seals to pull back. Any suggestions?
davester Posted February 12 Posted February 12 did you look in the owners manual? that typically describes how to replace the external lights, if they are replaceable.
big_chev Posted February 12 Author Posted February 12 It doesn't say. It points out to a model that has halogen bulbs. For anymore questions "contact dealer" it says. i also saw somewhere that some models have a sealed led headlight. But I can't seem to conform this. Im able to remove the connector but the socket won't turn. Unless it not supposed to.
66ss3964spd Posted February 12 Posted February 12 Headlight type is mostly driven by trim level, you didn't mention yours. But from your description and from what I've read in the 2023 OM, it sounds like you have LED's. In the 2023 manual, in the Vehicle Care section, page 358, it does talk about bulb replacement for the base trim level. For Mid and Up level trims it says only "...see your dealer". Regardless, there's a specific warning in the manual that states "Do not replace incandescent bulbs with aftermarket LED replacement bulbs. This can cause damage to the vehicle electrical system." So even if you did have incandescent bulbs you'd not want to install LED's - at least not while still under warranty.
big_chev Posted February 12 Author Posted February 12 Sorry. I have a 2024. (Refreshed front) turbomax LT. Doesn't have halogen lights. I can see from the outside that the high beam has a couple LED diodes inside the light.
newdude Posted February 12 Posted February 12 11 minutes ago, big_chev said: Sorry. I have a 2024. (Refreshed front) turbomax LT. Doesn't have halogen lights. I can see from the outside that the high beam has a couple LED diodes inside the light. Time to return those bulbs then and get your $$ back.
davester Posted February 13 Posted February 13 Yeah, when it says "contact dealer" that means it's an assembly and the bulbs aren't replaceable.
Register a new accountSign in
