2012 Yukon XL Denali 172000 miles 6.2L. Owned for 10yrs and no problems until early last year
For the first 9yrs no issues and now this.  I have had this random problem for a year now. It will run fine for several weeks. No engine problems for 100's of miles and then today: Truck is cold when this happens (not yet at normal operating temp of 210F). No noises, no codes or check engine light. Drive down the street 2 miles and from a stop sign turn left and start to accelerate when the truck starts surging, RPMs jumping and acting like it will die. Sometimes it dies and sometimes it doesn't. Once the engine is warmed up it does not do this. Always happens before engine is at normal temp and less than 45mph.  Sometimes I get in like yesterday and it sat all night and drives just fine no problem. Very random problem and the majority of the time the truck starts and drives just fine. Over the last year I have installed:
New OEM fuel pump and sensor
New throttle body
New MAF sensor
New crank sensor
New fuel injection sensor
New coil packs and plugs
New EVAP purge solenoid
New coolant temp sensor
New OEM negative battery cable set
I have tested the fuel pump pressure with gauges and pressures are normal at idle and while driving
I have been told this maybe a ground problem but I cannot find a diagram to show me where all the grounds are for this truck.
I have a TOPDON bidirectional scanner.
I'm at my end and ready to plant tannerite in this thing!
Any help please?
This to me is screaming of an intake manifold gasket leak. Those can seal up tight when warm. You're feeling a lean misfire when cold, is what I'm guessing.
Good way to test is with a bottle of water with a hole poked in the cap. On a cold engine, squirt the water along the intake manifold mating surfaces at the cylinder heads. If it's bad enough you'll actually hear the water getting sucked in, and the tailpipe steam will get extra thick.
Any change in the way the engine runs after squirting water along that junction is an indication of a leak.
Since the engine is cold, the fueling isn't relying on many (or any) sensors for inputs - that's why you're not getting a flashing check engine light.
9 years with no trouble - that's a KEEPER!
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
