Rust on my 2002 Tahoe?!
I found a spec of rust on the driver's side rear quarter panel. The backside of the spot isn't accessible via the wheel well. I know that Chevy has a 6yr/100000 mile rust through warranty, or something like that, but I was shocked to see this on a newer vehicle.
At first, I assumed it was rusting from the inside out (bad), but now that I think about it, after I sanded it and took a fine grinding stone to the metal, it cleaned up really well, leading me to believe I had an external chip that just starting surface rust. And the fact that the backside isn't exposed to the elements makes me wonder how it could be (inside out rusting).
The repair I did myself came out very good, and after a compound and wax of the area tomorrow night, it should be hardly noticable. just like a touched-up chip on the hood.
Anyway, my question is, has this happened to anyone else's newer truck? Did you have Chevy repair it, and if so, how did they go about it/fix it? Obviously, if it begins to rust again, I'll be heading to the dealer so I wanted to know what you've all experienced.
Thanks
You should see the rust around my hood latch..
Mine too! also the bottom of the front doors near the rubber the paint there is bubbling so i peeled some of it off and sure enough RUST not to mention my bumpers and on a new truck :cool: what a joke
:cheers:
Yes, I had paint bubbling along the bottoms of the doors as well. The way the sheet metal is folded allows moisture to sit around there. The dealer had a local bodyshop repaint them, and then I coated them with POR15 clear paint. It held up fairly well, but they're bubbled again. I may need to recoat to protect them once again, but I'll have another repaint done somewhere down the line if I see it being a problem. I'd just remind everyone to check the areas out if you live in a snowy/rainy area.
    250.3k
    RobbertClaus
    RobbertClaus
  • Who's Online   5 Members, 0 Anonymous, 508 Guests (See full list)
    • No I didn’t watch a video of a person who analyzes oil for a living explain general oil usage. For clarity I did ask my brothers one who runs our equipment business. The other who runs our old ROW business about oil usage. Nothing has changed since I retired. Their personal vehicles or work vehicles use no oil. Not enough to see on the oil checking device. Then I pondered. I like to ponder. In this extended oil changing world with oil change countdowns or lights. If engines used say a qt every 2500 miles or up to even 4000 miles. With oil changes reaching as high as 15000 miles. Normal for most people is eight to ten. Vehicles should potentially be seizing up all over the place. Especially in hilly terrain. Just how many people actually check their oil? Maybe 10 percent. Those are the people that probably change their oil early. I like to research used car listings. I have five favorite dealers I check. They all list carfax with their listing. It’s rare to see vehicles with anything but extended oil changes. Transmission service, forget about it. I’ve seen Honda and Toyota certified vehicles up to 100K miles and ten years old. With nothing but normal maintenance. Isn’t nice we all have different experiences and believe our way is the best. You certainly get backup for whatever you believe. Life would be boring otherwise.
    • Interesting rumor. Dealers near me have been tight-lipped so far, but if this reveal actually happens next week, I'm really hoping they finally give the HD a proper interior overhaul. The competition has been eating their lunch in the cabin department for a while now.
    • There are a few good takeaways in that video that pertain to this thread, certainly the possibility of the oil control rings having buildup, the fuel injectors and how clean or not that they are ending up affecting the pistons rings carbon buildup, and the fact that its normal up to a point for a given engine to use some oil, and that the oil quality that is being utilized is part of that ring clogging up issue as well.   I was talking with a neighbor yesterday who has a baby LZ0 duramax and he had bought it slightly used but it does consume some oil and he has switched over to 5W-30 Euro spec oil and in this case that never made a difference in consumption over the factory 0W-20 recommendation. He finds it uses a quart in about 3500 miles and as he goes a ways over that distance he adds oil to full and goes another 1000 miles or so and then changes oil and is typically at 40% or so left on the oil monitor at that point with his use case of quite a lot of highway miles and more limited in short run use. I don't know what other LZ0 engines are doing for oil consumption but that is what his is doing.
    • I dont care what Lake says. Goodnight.
    • Ok well I guess Lake disagrees with me on a few points. I call oil consumption pretty basic. Rudimentary. He calls it "really complicated." I think 1qt consumed in 3k miles is a lot. He says that's normal. In 22 minutes, he'll use his natural talent to explain oil consumption to anyone watching this video. He covers everything from obvious engine damage to how normally functioning healthy engines consume oil by design. Lake explicitly states how you drive will impact oil consumption.   Shut up and watch:
